Trans. cooler lines
Old Apr 24, 2010 | 06:53 PM
BTM's Avatar
BTM
Trans. cooler lines
Hi, I replaced the radiator in my Buick last week and fluid is leaking from the adapters. What can I use on the threads? ( blue RTV, teflon tape?). Thanks, Rich
Old Apr 25, 2010 | 12:29 PM
whiteeye42's Avatar
try some teflon thread tape or some pipe dope
Old Apr 26, 2010 | 06:59 AM
Jim Lane's Avatar
Teflon Tape,
Are you sure you have the correct thread adapters for your lines on the replacement radiator?
Old Apr 27, 2010 | 12:02 AM
stinkindiesel's Avatar
I did that once- I used tapered into straight (or was it the other way around?) and I never got it to stop seeping. Make sure you're using the same thread taper- NPS and NPT aren't compatible.
Old Apr 27, 2010 | 02:19 AM
Jim Lane's Avatar
I run into this all of the time except for home appliances, tenants will install a stove, BBQ and even water heaters and try to screw a flare or inverted flare onto an iron pipe thread, they will fit but they will leak like crazy It amazes me just how not smart some people are.
Sometimes it hurts my head when my high mechanical intelligence has to deal with low or no intelligence.
Jim
Old Apr 27, 2010 | 05:21 PM
BTM's Avatar
BTM
I used the adapters that came with the new radiator. Thanks for the replies, Rich
Old Apr 27, 2010 | 10:27 PM
jbjarko's Avatar
Who knows if the RAD you got is NPT, or NPS. Double check. Teflon tape when required.
Old Apr 29, 2010 | 07:08 PM
BTM's Avatar
BTM
Josh, what is NPT & NPS? Rich
Firstgenfanatic
Jan 29, 2008 09:21 AM
EClancy
Jan 16, 2007 09:27 AM
robox
Nov 4, 2005 01:33 AM
MrKen
Feb 25, 2005 04:22 AM
USMC64-70
13
Oct 23, 2002 06:58 PM
