Electrical Code
Old Aug 24, 2006 | 03:22 PM
spitfire9137's Avatar
Electrical Code
ANyone know where I can find electrical codes for the sate of maryland, cecil county, online? Or maybe someone on here happens to be familar with it?
Old Aug 25, 2006 | 01:14 AM
rockwithjason's Avatar
The best thing to do is to call your building department and see what they have to offer. Very few jurisdictions have their codes online. Ususally you have to buy the publications.
Old Aug 25, 2006 | 10:01 AM
spunbearing's Avatar
If you go by the NEC you should be ok. I know that California is supposed to get away from uniform codes in 2007 and go to the international code published by ICC. I have a copy of the 1999 NEC if you need me to look up anything. My inspectors test was based on the 1999 NEC so I don't have the newer copy.
Old Aug 25, 2006 | 02:28 PM
Well we built a garage next to our house. The power to the garage will come off the main service line to the house in our basement. There will a breaker down there, now the panel in the garage, does it need to be a main lug or a main breaker. I would prefer and think that a main breaker would be better since it will be so far away from the breaker in the basement that is feeding it. Need to know so I can buy the panel for the garage.
Old Aug 26, 2006 | 08:41 AM
berner's Avatar
I'm in the process of putting up a garage right now too. I've looked through the Canadian Electrical Code but find it quicker to just phone the power company and talk to an inspector.
Old Aug 26, 2006 | 11:26 AM
The way that I understand the codes in article 225 and 210 you don't necessarily need to have another main panel as long as the sub panel has between 2-6 breakers and they are grouped in a way that you can click them all off at the same time in an emergency. If you have more than 6 breakers you need a main disconnect.
Old Aug 26, 2006 | 02:20 PM
Alright thanks spunbearing.
moparman13045
May 23, 2012 09:41 AM
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
