Civilization, yes............
Ahhhh........the entrapments of.........errr......trappings........ that's trappings of civilization - power, lights, microwave, telephones, a soldering iron - how granted we take them - how dearly they are missed - yep, AC power back today at noon, two weeks after Ike - never realized, everything I do takes electricity and light - sun goes down, technical life is over - sure glad for L.E.D. lighting, runs 40hrs on 3 AAA penlite cells, even longer on AA, way longer on D cells - the time of the incandescent bulb is over, imo - drop an incandescent and you're dead in the dark - drop an L.E.D. multiple times with no resultant D.E.D.'s (dark-emitting diodes) - life is AC powered......................
Thanks - Alicia in '83 felled the neighbor's 100yr oak onto my property, across both vehicles and the front of my house - took 6wks to remove that after work everyday and weekends - never lost AC power - Ike felled that tree's 125yr sister along and across my fence, shearing four limbs off two of my trees but missing the house - only actual wind damage to my trees twisted the tops out of the two across the back bedroom, which fell away from the house into the back yard - one hundred wheelbarrows of just leaves\twigs\small branches from wind-shear strippage, then the big limbs\branches - I did it in three days - a 20" Oregon Barracuda chain\blade on a Montgomery Ward's (McCulloch painted orange) 3.7cuin saw made it very easy - 12"dia limb in under 12secs, only gravity working the saw, no hand pressure - that chain is the (Looney Tunes') Tasmanian Devil of chainsaw blades - when I walk into the backyard with that big orange saw, the trees all pull up their branches and try to look healthy - after they saw the Barracuda in action, all I have to do is point at a limb and a ground location, and the selected tree will drop it on spot - the others try to maintain a low profile, not moving even if the wind is up............
The Oregon Barracuda: try it - you'll like it.............
Becareful hooking up those Light Emitting Diodes backwards, if you do they suck the light out of the room. Glad you got power back. Ike was a weird storm. Up here in the Dallas area, we got a little rain (which we needed) and not much wind at all). My parents way up in the NW corner of PA lost power for a few hours.
~Rob
~Rob
BarryG
04-01-2003 03:07 PM
97CTD
01-14-2003 08:47 PM
