chains
Old Oct 19, 2008 | 03:48 PM
ian515's Avatar
chains
what do you prefer on the end of your chains for towing/recovery? slip hooks, grab hooks, j hooks?
I have straps as well, but want to get my chains setup right too....grab hooks dont work too well for hookin up to the tow hooks on the truck, but if the other options are a bad idea, I will just stick with the grab hooks.
and just out of curiosity, when do most use chains over straps and vice versa?
Old Oct 19, 2008 | 05:28 PM
Fronty Owner's Avatar
I have grab hooks on all my chains. I dont use them for towing however.
Old Oct 20, 2008 | 01:40 PM
SIXSLUG's Avatar
I switched over to straps for recovery purposes after having a chain come apart and blow out the rear window on a buddy's pick up. Don't ask.
Chains are great because they distribute load and don't bind down on the hooks where tow straps can get into an impossibly tight knot if you don't use them right. I use chains for securing loads and straps for recovery now.
Just two cents.
Kurt
Old Oct 20, 2008 | 02:10 PM
Timmay2's Avatar
I would agree with Kurt.
Use chains for securing down heavy loads where movement is minimal.
Use straps for yanking/pulling where the load is subject to shock, straps are much better at absorbing shock that comes with pulling.
Old Oct 20, 2008 | 02:58 PM
jbjarko's Avatar
Chains, straps with metal anything are dangerous as all get up.
Use a ****** strap for recover.
Chains are for securing loads.
Old Oct 21, 2008 | 01:53 AM
ofcmarc's Avatar
Use a strap for recovery, Get a couple of clevis' in different sizes to attach the straps with. I also have a short piece of chain with a slip hook on one end and a grab hook on the other just in case but don't typically use it for recovery.
Old Oct 21, 2008 | 05:41 AM
n2moto's Avatar
Rule #1 don't hurt your truck or yourself towing somebody out.
I keep chains on board (whips optional) with hooks to hook up to what I'm going to pull out if there are sharpe edges to cut my strap. If say hooking to a ball on a truck that's stuck I'll go ball to ball.
I'll throw a jacket or something over the strap to slow it down if it gives up the ghost.
Just use some common sence and you'll be fine.
Old Oct 21, 2008 | 06:36 AM
Hvytrkmech's Avatar
We use endless loop recovery slings. Different sizes for different needs. A 30' will work well for you guy's pulling out your friends trucks.
Tim
Old Oct 21, 2008 | 06:48 AM
Totallyrad's Avatar
Standard hooks on the chains for securing loads. I never use my load chains for pulling anything. I have other chains for light pulling. If I really need to bear down on something, I'll go back and get the cables and ******-block. Always use the right tool for the job.
Old Oct 22, 2008 | 06:40 PM
CNeubauer's Avatar
I like chains with grab hooks myself but I have chains strong enough for the job too. 90% of chains break because too small of a chain is being used or operator error. For heavy jobs I have a 25' long grade 80 5/8" chain that will stop a D6 dead in it's tracks so I'm not worried about breaking it.
Old Oct 23, 2008 | 10:27 PM
JKM's Avatar
JKM
I don't use chains for pulling on things that are stuck ... not very often anyways
Of course , a cable, and a big winch are handy sometimes too
Old Oct 24, 2008 | 04:12 AM
apprentice's Avatar
Endless round Slings
Most versatile and widely used sling. The economical answer to most lifting problems, ideal for vertical, choker, and basket hitches. we used these for ALL HEAVY lifts 10-100k pd lifts @ nabors drilling... a 50' sling plus 2 cleveses = 4 lines @ 25'= safe recovery
KATOOM
Dec 2, 2003 11:00 AM
Yossam
14
Nov 30, 2003 06:37 PM
bigfoot
Feb 27, 2003 06:42 AM
TEDHRS
Jan 22, 2003 08:29 AM
thatguy
Dec 11, 2002 07:22 AM
