92 d250 gas low oil pressure
Old Feb 22, 2009 | 10:43 AM
chessman21's Avatar
My oil pressure never gets past the 25% mark on the gauge. It doesnt seem to smoke at all but after about 20 minutes of hiway speeds i can here a tapping.
It could be a manifold gasket Im not sure. Would it be a good idea to replace the oil pump? What about the "high flow" pumps, would one of those be advisable?
Old Feb 22, 2009 | 10:53 AM
Free89W350's Avatar
If you don't have one I would put a mechanical guage on it first. Mine had real low pressure on the factory guage and my oil light would come on then I put on a mechanical guage and saw that the pressure is fine, 60psi cold and 35-40 at highway speed. The factory sending units are junk in my opinion. For the tapping issue have you adjust the valves lately that might fix that problem.
Old Feb 22, 2009 | 11:26 AM
chessman21's Avatar
The machanical guage screws inplace of the original gauge? The one beside the distributer?
Old Feb 22, 2009 | 11:42 AM
Free89W350's Avatar
I put mine right above the oil filter and ran the line into the cab, or you can take the original sending unit out and put it in there. It is the piece that sticks out of the block on the driver side between the cab and the VE pump with one single wire coming off of it.
Old Feb 22, 2009 | 11:44 AM
comptz's Avatar
i believe that he is talking on a gas motor.
Old Feb 22, 2009 | 11:51 AM
Free89W350's Avatar
I must have missed that .
Old Feb 22, 2009 | 01:29 PM
Field_boss_cb's Avatar
If the oil pressure is going down low, the hyd. lifters will start making a lot of noise and give a warning that the oil pressure is getting low, that may be the noise you are hearing. There is more than likely there is enought oil pressure for the bearings and no damage has taken place, but needs to fixed now. I would install a oil pressure gauge like was said before, to find what is really going on.
Old Feb 22, 2009 | 05:42 PM
chessman21's Avatar
ok guys, i will locate the oil pressre unite and fit it with a mechanical gauge and see what it reads. Thank you for you advice.
Old Feb 23, 2009 | 01:03 PM
89D250's Avatar
I would hate to ask a stupid question but have you checked the oil level? I have a 383 big block and when you would accelerate you would here pinging. Come to find out that the oil level was low. Also you might have collapsed lifters and that would make the pressure low too I think.
Old Feb 23, 2009 | 07:44 PM
383 big block?
Old Feb 24, 2009 | 06:02 AM
Free89W350's Avatar
For mopar they had the 383 400 413 426 440 and I think I am forgeting one or 2, all are concidered big blocks. Unlike the chevy small block 350 stroked to a 383.
Old Feb 24, 2009 | 07:52 AM
olddodgetrucks's Avatar
only missed one 361
Old Feb 24, 2009 | 10:32 AM
I jumped to a conclusion that is was a Chevy engine you were refering to.
I thought how did they make a 383 big block (Chevy) Now see what I was missing.
Old Feb 24, 2009 | 04:11 PM
chessman21's Avatar
OD issue again.
I thought I had the proble solved but its not working again. Now i have hooked a wire from the pcm ground to a test light.. The Light stays on till the truck reaches od speed then goes out, When i slow down to a stop the light comes back on.. The hot wire comes on with the key and stays on.. So I assume the od solenoid is getting juce. What about the tranny fluid pressure?
I dont know if that has anything to do with the od.
Power Ram 250 C
Feb 20, 2007 11:08 AM
searcher
Oct 16, 2005 11:03 AM
Cummins600
Jun 27, 2005 11:37 PM
