Oil overflow & no/low oil pressure
Old Jun 18, 2005 | 08:48 PM
Cummins600's Avatar
Bad injector - Oil overflow & no/low oil pressure
While idling I received a check gauge light & I had no oil pressure. After moving the truck I got oil pressure again and soon parked it. Then I noticed oil on the underside and rear of the truck. Then I checked the oil level on the dipstick and it read high. I plan to check the anti-freeze level in the radiator to see if it is leaking into the motor. Does anyone have an idea what could be causing this.? Any insight is much appreciated.
Old Jun 18, 2005 | 09:25 PM
MikeyB's Avatar
Most likely a stuck injector and it's leaking diesel fuel into the crankcase. Get it to the dealer ASAP.
MikeyB
Old Jun 18, 2005 | 10:24 PM
Cummins600's Avatar
The anti-freeze level in the radiator is good. So, a stuck injector it might be. What a pain to deal with! I'll let y'all know.
Old Jun 18, 2005 | 10:30 PM
ramruff's Avatar
My 04.5 had a bad injector and overfilled the crankcase by abot 1.5 gallons...........I still had oil pressure .......I caught it early.......tow it to the dealer or a cummins repair facility .........they made mine right under warranty............Tom
Old Jun 20, 2005 | 09:35 PM
Cummins600's Avatar
I really hoped the extra cash for the CTD motor would provide extra reliability and I wouldn't see this site.......wrong. The dealer had it all day long and didn't figure much out to the cause of the problem. They said they have to call D/C engineering before they start to tear-down & replace parts.
Old Jun 20, 2005 | 10:38 PM
ramruff's Avatar
Here's a link to when my truck got to ride the flatbed too: Diesel in engine oil It gave me a starting point of what to look for.........good luck.........Tom
Old Jun 20, 2005 | 10:55 PM
Cummins600's Avatar
Thanks ramruff, I didn't find that post in all my searching on this site (way too limited). I really hope the bearings didn't suffer a bit through this. The motor seemed to run and sound just the same as before - very good.
Old Jun 20, 2005 | 11:23 PM
nickleinonen's Avatar
i wouldn't worry about the bearngs within the engine [mains, rods, pins, cam bushings] but the turbocharger bearings i do worry about when i hear about fuel dilution... they are under very high speeds... but if endplay and radial play is ok on the charger, it'll be ok to use
Old Jun 21, 2005 | 08:51 AM
bigblock2stroke's Avatar
That's like bolting a 16 psi supercharger on a stock gas engine and wondering why it blew up, Mr. Quad race box.
Hope you're gooooooood friends with your dealer.
Old Jun 21, 2005 | 02:04 PM
Cummins600's Avatar
Thanks, I am good buds with him. He has it on his truck now while I can't use it. He needs new tires now.
Could it have done something? Maybe.
Old Jun 21, 2005 | 03:33 PM
Do a search. Lots of discussion on injector damage from pressure boxes. Quad himself did a couple posts about it.
Old Jun 27, 2005 | 11:37 PM
Cummins600's Avatar
DC's Star Center called the shots for the dealer on this one. # 5 injector was replaced & changed oil and filter. All seems to be well now. Roadside assist picked-up the truck within 40 minutes of my call and warranty covered all fees 100%.
MNorby
Feb 2, 2012 08:51 PM
roanokerivermud
Jun 12, 2009 11:21 AM
Buzz'nhalfdozen
May 27, 2009 12:19 AM
Ru rammin 2?
34
Jan 23, 2008 07:21 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
