why does 5 gear slip out so easy
whay does 5 gear slip out so easy in mt 6 speed nv5600 it did the same thing in my 1999 5 speed. If i put any amount of pressure on the shifter or hi a hard bump in the road it does this i only have about 7,000 miles on the truck.
2005, 3500 DRW, 4x4, white slt,6 speed,
i can slip all my gears into neutral when i break torque [let off the throttle] with nearly zero effort, but if it is any under load [throttle or coasting] i can't pull it out, and you shouldn't be able to pull it out... why yours is coming out of gear on its own on a bump is a ??? to me
txsmokindiesel
May 19, 2009 08:03 AM
VikingDiesel
17
Dec 30, 2006 09:19 AM
BADodge2003
Aug 24, 2003 07:22 PM
