92 Celica ignition probs
Old Dec 13, 2005 | 10:09 PM
hotmopr's Avatar
I also couldnt find the coil.. Left side (pass side) against the firewall?
Old Dec 13, 2005 | 10:11 PM
hotmopr's Avatar
Originally Posted by spunbearing
Do you have a digital camera? If you do take a pic of the distributer with the cap off and send it to me so I can see what you have. The toyotas I have worked on have the coil under the cap. I have a 92 corolla so it should be similar. I have the manual on the corolla but they may have different engines. You may want to try to pull diagnostic codes too. May give you an idea.
How do you pull the codes? I would bet its under the cap too...
Old Dec 13, 2005 | 10:22 PM
Buckshotmckee's Avatar
I found a picture and looking at the engine, the coil should be sitting on the (L) side of the brake booster about 1/2 way down.
Old Dec 13, 2005 | 10:26 PM
Try this. This is from All-data
* Turn ignition switch and O/D switch to on.
* Do not start the engine.
HINT: Warning and diagnostic codes can be read only when the overdrive switch is ON. If OFF, the overdrive OFF indicator light will light continuously and will not blink.
Check Connector
* Using a jumper wire, short terminals TE1 and E1 of the check connector.
* Read the diagnostic code as indicated by the number of times the O/D OFF indicator flashes.
Normal Code
* If the system is operating normally, the light will blink once every 0.35 seconds.
Malfunction Code
* In the event of a malfunction, the light will blink once every 0.5 seconds. The number of blinks will equal the first number and, after 1.5 seconds pause, the second number of the two digit diagnostic code. If there are two or more codes, there will be a 2.5 seconds pause between each.
HINT: In the event of several trouble codes occurring simultaneously, indication will begin from the smaller value and continue to the larger.
Old Dec 13, 2005 | 10:42 PM
hotmopr's Avatar
I will run out and look for the coil. My car also has a 5 speed so there is no OD switch... I'll go try the jumper and see if anything flashes..
Old Dec 13, 2005 | 10:49 PM
hotmopr's Avatar
I still didnt find the coil. Left side of the booster. The only thing there is the heater control valve where it passes through the firewall. the other side of the booster has the slave cylinder for the clutch..
Old Dec 13, 2005 | 11:02 PM
hotmopr's Avatar
Okay I ran the codes and no problems the check engine light does the blinking on a 5 speed...
Old Dec 13, 2005 | 11:15 PM
If you found the ignitor, above the booster, then the coil should be sitting underneath it slightly to the (L) according to the diagram I have.
Old Dec 13, 2005 | 11:39 PM
hotmopr's Avatar
Negative ghostrider.. Its full of brake lines and vac hoses and water hoses....
Old Dec 14, 2005 | 12:16 AM
PistolWhipt's Avatar
Are you the original owner ?? If not ... there may have been some "fingers" in there trying to modify the system and moving / removing parts for you.
ALLDATA usually has some pretty accurate drawings.
PISTOL
Old Dec 14, 2005 | 04:21 PM
ChrisLib's Avatar
The coil is under the dist cap, and it is a common failure item. Just replaced one last month. If you need I can look up the ohm specs and such at work tomorrow but my bet is on a bad coil.
Old Dec 14, 2005 | 07:37 PM
hotmopr's Avatar
How do you test it? Do I have to change out the whole distributor? looks like a one piece item..
Old Dec 15, 2005 | 01:03 AM
hotmopr's Avatar
Takin it to the top
S_Wilson
Sep 5, 2007 03:59 PM
midwestdually
Apr 22, 2003 08:46 PM
ridofpwrstroke
Mar 7, 2003 11:13 PM
hellotbone
Jan 20, 2003 06:56 AM
hellotbone
Dec 29, 2002 08:28 AM
