Sponsored by:
Sponsored by: CARiD
87 int. dt466 engine probs
Old Apr 22, 2003 | 04:08 PM
midwestdually's Avatar
i got an 87 international s1600 dt466 and i cant get it started...i was crankin it over and all of a sudden it stopped cranking....i have full juice ....i thought it was the starter but i whacked on that with a hammer for a bit thinking the starter was stuck but to no avail....any suggestions?
Old Apr 22, 2003 | 05:38 PM
bneaves's Avatar
Re:87 int. dt466 engine probs
Check the signal wire (small one) to solenoid to see if it is getting 12V. If not look for an ignition relay. I would believe that the relay took a dump since it stopped all of a sudden. Should be a standard T-85 unit, probalby in the fuse panel.
Old Apr 22, 2003 | 06:16 PM
i got the clicking noise when it is on run but when i try to start it the clicking stops...
Old Apr 22, 2003 | 06:46 PM
where would the relay be located and where is the solenoid located??sorry..these things are kinda greek to me
Old Apr 22, 2003 | 07:49 PM
bneaves's Avatar
Sounds like you could have a failed battery, they can puke all at once. I would first find the fuse panel, probably under the dash on right hand side or in left kick panel. If the relay was OK, swap with another to test that theory. Then I would load test batteries, if all good, then go to the starter, there is a small round tube on top of it that looks to be about the size of a V8 juice can. There should be a small wire running to it, about half the size of a pencil. Take a test light or a multi meter and see if it has 12 volts while key is in start position. If you are still having trouble PM me and I will give you my number here @ work that you can call me until 1100 ET. Brian<br>
Old Apr 22, 2003 | 08:46 PM
brian....it is now dark out and it is outside...i will have to resume tomorrow morning<br>
enginedude
Oct 21, 2004 04:18 PM
GO 4LO
15
Jul 28, 2004 01:47 PM
whytywythnostyle
Mar 16, 2004 09:13 AM
Diesel Freak
May 3, 2003 09:40 PM
