Windows Frozen, Why?
Old Nov 7, 2002 | 07:53 PM
drecu's Avatar
Hey guys! I was driving my truck tonight &amp; for some reason we hit the window button &amp; my windows are frozen shut, could water have gotten in there? it is below freezing out right now so that's my only guess, but how can I stop this from happening again? did any of you ever have this problem?<br><br>Thanks!<br> DRecu!
Old Nov 7, 2002 | 08:01 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Re:Windows Frozen, Why?
They are frozen because it is WINTER! <br> Mine do the same thing, water gets in between the edge of the seal and the glass, usually only takes a short while for them to thaw with the defrost on high. Can be a pain when you stop at the mailbox on the way out though <br> If you look at the bottom of the inside of the doors you can see the weep holes for the water to drain out. Water passing through the doors is not uncommon usually just becomes a problem if those holes get plugged up.
Old Nov 9, 2002 | 11:38 AM
Smokee's Avatar
Yes, it is WINTER. Try spraying around the rubbers with silicone spray. It may help. Mine freeze too.<br>george
Rednecktastic
Nov 15, 2010 09:29 PM
smokeyram
Nov 10, 2008 10:31 PM
sgrooms
21
Apr 8, 2008 11:17 AM
04ctd
Dec 23, 2006 08:23 PM
markster
Oct 7, 2006 02:20 PM
