Windows Frozen, Why?
Hey guys! I was driving my truck tonight & for some reason we hit the window button & my windows are frozen shut, could water have gotten in there? it is below freezing out right now so that's my only guess, but how can I stop this from happening again? did any of you ever have this problem?<br><br>Thanks!<br> DRecu!
Re:Windows Frozen, Why?
They are frozen because it is WINTER! [laugh]<br> Mine do the same thing, water gets in between the edge of the seal and the glass, usually only takes a short while for them to thaw with the defrost on high. Can be a pain when you stop at the mailbox on the way out though ;)<br> If you look at the bottom of the inside of the doors you can see the weep holes for the water to drain out. Water passing through the doors is not uncommon usually just becomes a problem if those holes get plugged up.
Yes, it is WINTER. Try spraying around the rubbers with silicone spray. It may help. Mine freeze too.<br>george
