weight for traction
Old Dec 16, 2005 | 11:09 AM
Micaiahfied's Avatar
weight for traction
hey, the only reason i am posting emergency is that i am leaving in about 2 hours. i am heading up to ny with my 2wd truck. i need to know how much weight i sould add in the bed of the truck so that i can get decent traction. i was going to use all purpose sand bags and put them inbetween the wheel wells. but i don't know how much weight is good. i used to put 6 50 pounders in my s-10... but no clue on a big truck like this. thanks
Old Dec 16, 2005 | 11:31 AM
DSjockey's Avatar
I used to use 5 of the 70# sand tubes they sell at Home Depot in my 80 F150 with BFG all terains and probably should have put in a couple more for the bad spots of solid ice but only used the 4X4 maybe once a season on the worst days
Old Dec 16, 2005 | 11:34 AM
i've got a shell on it, and a probably 200 pounds + or - in the back... would 10 50pounders be overkill? i like the sand cause i can bust it open and use it for traction if needed
Old Dec 16, 2005 | 11:45 AM
DSjockey's Avatar
I would go with the 10 50s, much better to have more than you need than not enough, and I did the same thing, kept an entrenching tool in the back to throw down some sand if I had a problem getting started on the sheet ice
Old Dec 16, 2005 | 11:51 AM
thanks for the help... i am off to the store, then 16 hours on the road!
Old Dec 16, 2005 | 12:04 PM
DSjockey's Avatar
Have a safe trip
Old Dec 16, 2005 | 12:19 PM
Bad Ramer Jamer's Avatar
Don't get any sand in your short's. Happy trail's, be safe.
Old Dec 16, 2005 | 01:55 PM
Wolfeman's Avatar
You have probably left by now but I suggest at least 600lbs near the tailgate if you are in snow.
Old Dec 18, 2005 | 03:55 PM
wolfeman, i am here now. i have 500 in sand, plus the cap that's probably another 200 or more and then tools and luggage. if i have any trouble i will move the sand back towards the tailgate.
Old Dec 19, 2005 | 09:08 PM
Crimedog's Avatar
I used to run 1000 - 1300 lbs right at the tailgate when we plowed But then again the plow weighed over 1000 lbs........
Old Dec 19, 2005 | 10:01 PM
HOHN's Avatar
I'd say 700-800lbs as far back as you can get.
My truck empty weighs 4100# front axle, and 2710# rear.
Adding 1400lb to the bed to make 50/50 weight distribution would be ideal, imo.
jh
Old Dec 20, 2005 | 05:56 AM
Shovelhead's Avatar
Administrator / Scooter Bum
What ever you decide to use for ballast, tie it down securely.
Newton's First Law of Motion:
A body in motion will remain in motion UNLESS ACTED UPON BY AN OUTSIDE FORCE.
(a securing strap, tie down, etc)
In the event of a collision, it WILL come through the back window.
Mass + Velocity =
Old Dec 20, 2005 | 06:14 AM
mikmaze's Avatar
& plan your fuel stops wisely, a lot of ripoff stations near the on and offramps of the major rosads, cary some extra and look at a fuel price site to find the lower prices, you may save at least 50 cents a gallon, that can add up. Wher to in NY? city? close by if ya need a hand.
Old Dec 20, 2005 | 04:51 PM
mikmaze's Avatar
how was your trip? I see you are online.........................
John Marshe
Aug 14, 2020 09:00 PM
12PACK
32
Jan 7, 2014 12:19 PM
Purplezr2
Jul 25, 2011 04:31 PM
mestdagh
Jan 8, 2007 04:40 PM
I SPEED
22
Nov 16, 2004 11:52 AM
