bad shake at high speed hop at low speed
This is my first diesel and i love it but for the life of me i cant get the shake out the old girl replaced tires hand them rebalanced ive got custom wheels on it that were on it when i bought im lost but it getting to the point were i cant drive it on the highway help
Are you centering them with cone lugnuts when you install them? I seem to recollect that if you just slip them on and tighten the flat-sided lugnuts, you're almost guaranteed to be off center.
I doubt that a bent axle would cause the hop and bounce and I think the "death wobble" was basically a 4x4 problem.
Check out this thread. I'd suggest starting here.
https://www.dieseltruckresource.com/...t=center+wheel
You may need to have them balanced at a tire store, that has the stud adaptor. It the center hole in the wheel is not centered, and they balance them using the center hole they are still out of balance. Some of the after market wheels have this problem. A good tire store should be able to help you find the problem. Sears and Wal Mart don't count, a place that does everything from car tires to 18 wheeler tires is what you need.
1stGen72
Nov 3, 2009 05:41 PM
Hummin Cummins
Apr 13, 2008 04:35 PM
