Water Pump
Old Jun 1, 2005 | 04:40 PM
Flashdancr's Avatar
Question Water Pump
My water pump sounds like a squealing belt and has a death wobble going on. Time to change it!
The crappy manual I have says to remove the fan.
Looks to me like all you have to do is drain coolant, remove belt, remove 2 bolts. Is that right or am I having a blonde moment?
They show a picture of a diesel water pump in the manual (I like it when they have pictures ) I see it has an 0 ring. Do they also have a mounting surface gasket or is it a milled surface where you would just use a little permatex. Manual doesn’t say and I haven’t taken it off yet to know, only want to make one trip to the parts store.
Thanks
Old Jun 1, 2005 | 04:54 PM
You are correct, all that needs to come off is the belt and 2 bolts.
There is only the O-ring for a gasket. No blue goo needed or wanted.
The thing that takes the longest is draining and refilling the coolant.
Old Jun 1, 2005 | 04:56 PM
Flashdancr's Avatar
Thanks Wanna!
Old Jun 2, 2005 | 07:33 AM
Smokee's Avatar
Yep///easiest waterpump repair that I have ever done. The belt is the only thing that is the least bit tricky.
I changed mine on the side of the road.
Old Jun 2, 2005 | 08:36 AM
FrdRdnk's Avatar
One trip to the parts store??? Wow you guys really are good!!! LOL
Old Jun 2, 2005 | 09:26 AM
Flashdancr's Avatar
I think we females are more organized than our male counterparts. We even read the instructions.
(The statement above does not reflect the majority opinion batteries not included)
Old Jun 2, 2005 | 09:36 PM
12valve@heart's Avatar
Instwhat?
I thought that paper in the box was to put under the old part to keep the dirt and grease from getting on the truck.
Old Jun 3, 2005 | 08:59 AM
Flashdancr's Avatar
Originally posted by 12valve@heart
Instwhat?
It is!
ted_pulliam
Oct 15, 2009 08:24 AM
RamWheelsBy4
Apr 11, 2007 04:43 PM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
