valve adjustment
you can reuse, but if this is the first time you have done the valves and don't know when it was off last I would without a dought change it. They tend to get dry rotted and cracked and will not seal good.
The intake valves should be set to .006 to .015 inch clearance, and the exhaust valve lash should be set to .015 to .030 inch.
My recommendation is to set them every three years, and set them to the loose side at about .010 on the intake, and .022 on the exhaust. If you do them every year, then set them as recommended by fschiola and that will give you the best power and economy. They tighten the clearances as they wear.
Fishbait
Nov 23, 2009 11:21 AM
blackboat
Nov 8, 2002 06:32 PM
