Valve Adjustment on 24 Valve ISB
Old Nov 29, 2006 | 09:29 PM
dhughe2's Avatar
I have a buddy who just adjusted his valves on his 95 CTD. I found the link to the valve adjustment procedure at https://www.dieseltruckresource.com/...n&onlynewfaq=1 . My question is, when do you know that you have to adjust your valves?
Old Nov 29, 2006 | 10:11 PM
dieselfan's Avatar
the service manuel recommends 150k. or excessive clattering at idle.
i did mine at 112k.
Old Nov 30, 2006 | 04:40 PM
Red3quarter's Avatar
I did mine at 65,000 and found several valves out of spec. After the adjustment the truck sounded less clattery and had better response and power.
Old Nov 30, 2006 | 05:37 PM
Gotlift01's Avatar
What's all involved in adjusting the valves.......I haven't done mine and I'm probably gonna be due to adjust mine here soon. Any tips?
~Nick
Old Nov 30, 2006 | 06:22 PM
m.rehme's Avatar
I adjusted mine at around 140,000 only needed to tighten down a couple just a little, just had them run again at 275,000 and same thing - nothing badly out of adjustment.
They are really simple to do.
Old Nov 30, 2006 | 08:33 PM
dieselfan's Avatar
~Nick
here you go. https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Dec 1, 2006 | 08:54 AM
Gotlift01's Avatar
SWEEET!!! Thanks man!!
~Nick
Old Dec 1, 2006 | 09:12 AM
RowJ's Avatar
On 24v's I have never seen or heard of one that was way out of adjustment ..... or even close!
And that's measured against the .010/.020 DTR recommended settings.... not just the WIDE allowable range listed by Dodge!
RJ
Old Dec 1, 2006 | 09:35 AM
bigdav160's Avatar
Just FYI, the clearances usually tighten up over time not loosen.
That's because most wear occurs at the valve and seat causing the valve to rise in the guide.
Old Dec 1, 2006 | 10:47 AM
dart4forte's Avatar
Valve Adjustments
RJ
The Commings tech I talked to said that the 24 valves rarely need adjustment. I took my 02 in for the adjustment and the service manager said to save my money and not do it. If Commings says that maybe they know what they are talking about.
Old Dec 1, 2006 | 11:13 AM
RowJ's Avatar
The valve guides, at least with added HP, are another story....
106,000 miles. 20 of 24 were like these!
RJ
Old Dec 1, 2006 | 06:01 PM
m.rehme's Avatar
bigdav160,
You jogged my memory - It's been while but I kind of remember of a couple running on the snug side but I did have several a few thousands loose. Probably all were within Dodge specs.
This last time I had a mechaniac run them and he indicated they were all very close, Only charged me $40. One thing he required was to let my truck set in his shop overnight to cool down before setting them.
Old Dec 6, 2006 | 07:12 AM
rowilson's Avatar
Pardon my ignorance but what the heck is a commings tech? Is it or could it be a Cummins tech?
Old Dec 6, 2006 | 07:40 AM
ronc's Avatar
Now that is pretty darn funny.
dieselfuelonly
Jan 26, 2007 11:11 PM
possum
May 24, 2005 11:30 AM
Mixer Man
Aug 17, 2004 10:36 AM
vtailflyer
Nov 7, 2003 06:19 PM
