ISB valve covers
Old Aug 15, 2004 | 01:46 AM
Mixer Man's Avatar
ISB valve covers
Has anyone tried putting the red ISB valve covers that Cummins shows on the RV engines on a Dodge ? Need to look close tomorrow ,maybe they won't clear the hood . Sure does look awesome though !!
Old Aug 15, 2004 | 10:21 AM
nickleinonen's Avatar
i'd like to get this black one to work [maybe have it painted blue, but this cover]
i scanned this off a cummins medium duty literature
Old Aug 16, 2004 | 10:40 PM
Mixer Man's Avatar
Yeah that is sweet !! Talked to Cummins dealer today about height ,would it fit ,etc..... Dude had no clue ,gave me part # and said 93 clams . I called Cummins direct ..........only made in black now ,like the one you showed and it MUST be a common rail cover . Told me it would fit and clear the hood though . Checking with dealer soon ,don't want DC to have any leverage on a warranty denial !!
Old Aug 16, 2004 | 11:01 PM
Smkndzl's Avatar
you wont be able to use the valve cover , what you dont see is that the cover in the back side has a oil drain on one side and a breather hole in the back , this valve cover will only work with the gear train in the back of the motor , and your valve cover on the dodge has the breather built into the valve cover itself . totally different .
Old Aug 16, 2004 | 11:26 PM
Mixer Man's Avatar
that pic is NOT a common rail though . Cummins swears it will fit and clear the hood. Guess I will have to be the guinea pig .
Old Aug 16, 2004 | 11:41 PM
Smkndzl's Avatar
That pic that Nickleinonen is showing is a common rail EGR engine that is use in the medium trucks . and yes the cover will fit , but it wont function
Old Aug 16, 2004 | 11:43 PM
Smkndzl's Avatar
you gotta remember , the CR engine that is use in the medium truck is not like the Dodge engine , the gear train is in the back of the motor along with the CP3 high pressure pump .
Old Aug 16, 2004 | 11:45 PM
Gypsyman's Avatar
Are we back to the breather at the back of the cover problem that Vaughn had with the one he was working on?
Old Aug 16, 2004 | 11:53 PM
Mixer Man's Avatar
So much for trusting the people that built these things . Thanks for the reply ,sure you guys are up on this ..........and I sure don't want to go through a bunch of needless cursing !!
Old Aug 17, 2004 | 10:36 AM
next time i go to cummins, i'll figure out what price i can get it for, and if it is reasonable, i will get one [canadian prices are different -usually more than us prices] and figure out some sort of breather setup...
dieselfuelonly
Jan 26, 2007 11:11 PM
dhughe2
13
Dec 6, 2006 07:40 AM
possum
May 24, 2005 11:30 AM
vtailflyer
Nov 7, 2003 06:19 PM
