transfer case guru's PLEASE!!
Old Jan 5, 2010 | 08:28 PM
catnfool's Avatar
I have my 241 dld out in my neighbors garage, with its cracked case and the replacement with the EXACT part #, out of a auto also, has an input shaft that is 3/4" longer!!
What are my options; how hard are these input shafts to swap? I took the seal off and looked at it, but it looks like I would have to split the case to swap them?
I am siliconeing my old case as we speak so my neighbor can have his garage back, but it is still on the bench.
got sawzall
Old Jan 5, 2010 | 08:55 PM
Checkmate's Avatar
Yup, split the case and keep track of everything. It's pretty easy. Did my 271 when I bought one for an auto to put behind my 6 spd.
Old Jan 5, 2010 | 09:09 PM
Copenhagenjunkie's Avatar
The assembly numbers are the same?
There is a .840" exposed input shaft and a 1.55" exposed input shaft and the difference is .71".
Old Jan 5, 2010 | 10:50 PM
catnfool's Avatar
ok- that would explain alot! I looked at some pics, and you do have to spit the case to change out the input shaft, right? How hard is this? Thanks, bruce
Old Jan 5, 2010 | 10:52 PM
catnfool's Avatar
I think I have to give up until the AM- neighbor is an early riser, so I don't want to wake him up tonight... I think I will just give the silicone some time to cure, and run the old case, unless I can find out how hard they re to swap. This thing has me frazzled...
Old Jan 5, 2010 | 11:01 PM
catnfool's Avatar
Checkmate- I just noticed your post Any special tools needed, or is it an OK job? I really would like to do this the right way; it's a pretty long crack in my original case, so it would always bug me...
I should have done my own work the first time- then I could blame myself for not getting the front driveshaft bolts tight
Old Jan 6, 2010 | 11:22 AM
ChargerLighting's Avatar
Its' not very hard to change the input shafts; a friend & I changed mine out a few years ago in my '96 gasser. Neither of us had ever taken a transfer case apart before but if I remember right its' just snap rings & smaller parts & remembering where they go.
Not too much for special tools; I think snap ring pliers were about the worst of it?
This is what you have to remove (in a 231D anyways) & change out.
Old Jan 6, 2010 | 09:50 PM
catnfool's Avatar
YEP!! That's the animal- I weakened at the last moment tho, and took them both to a tranny shop and let them take my $200 to give me it back all in one shiny clean working unit I don't get it back till sometime tommorow, but I have been screwing things up lately, and decided to pass on this one...
Old Jan 6, 2010 | 09:52 PM
catnfool's Avatar
thanks for everyone's help on this- like always, AMAZING place/people...
Old Jan 7, 2010 | 02:01 PM
dieselfreak21's Avatar
200 insurance if something goes wrong. Some time we work are our source of income so we don't always have to work on our toys. I think that is reasonable.
Old Jan 11, 2010 | 07:09 PM
JMZ's Avatar
JMZ
It`s easy. I can send you pics if you send me your email. Or I could post them.
Old Jan 23, 2010 | 02:40 AM
DodgemnLeavem's Avatar
email rec409@alaska.net
or post post post
Sharp929
Jun 5, 2014 10:03 PM
Mule Man Willie
Oct 23, 2011 01:00 PM
wyododge
Aug 18, 2011 07:48 AM
jmlcolorado
Oct 28, 2010 09:15 PM
