Sputter At Take Off
Old Oct 24, 2007 | 01:20 PM
klx300guy8's Avatar
They replaced the fuel actuator today and it hasn't sputtered yet. They mechanic says he is very confident that was the problem. My only question is what does the fuel actuator actually do. Does it control the amount of fuel coming from the injection pump into the rail (by the way it's an 03).
Old Oct 24, 2007 | 10:25 PM
ddt111's Avatar
The "motor vac" did not correct mine. Still sputtering. Where is the fuel actuator? I guess I've wasted some money.
Old Oct 25, 2007 | 07:51 AM
klx300guy8's Avatar
The way I understand it the fuel control actuator(FCA) is located on the injection pump. It controls how much fuel goes to the rail system. They guy changed it in about 1/2 hour. While I was there they also did a computer flash to update the computer. ddt111, how exactly does your sputter, because mine did it the worst after it would idle, for example at a drive thru or when sitting at red light.
Old Oct 25, 2007 | 04:45 PM
BigDodgeBigHart's Avatar
Originally Posted by klx300guy8
I have no evidence to say it's the injectors, but from the little I have read on this site it sounds like a possibilty. The "diesel" guy at the dealership said that when an injector goes bad it probably won't start, and if it does it will run too bad to actually move the vehicle. Could it be the injector pump? Also, is the covered under the cummins 100k warranty.
I had the same problem and got a injector pump from the guy on ebay and when replaced I have a great running truck now, also the guy on ebay saved me $1200 over a dodge dealership!
Old Oct 25, 2007 | 07:19 PM
ddt111's Avatar
My truck sputters when it idles. When I press the excellerator, the truck sputters but then once I get going it is fine. It doesn't matter where I am ie: drive thru, red light, parking lot. Occasionally it will sputter without pressing the excellerator. Today when I would stop at red light, I noticed the idle was fluctuating up and down. I forgot to look at the tach. Every morning the truck cranks fine, it idles, but when I press the excellerator, it stalls down. What does an FCA cost?
Old Oct 29, 2007 | 12:24 PM
klx300guy8's Avatar
That sounds similar to what mine was doing. Sorry, I don't know how much the FCA costs because mine was under the 100k warranty. I should have asked.
Old Oct 29, 2007 | 09:18 PM
ddt111's Avatar
I was quoted $2100. @ local dealership. Was informed that the FCA was only available with injector pump.
Old Oct 30, 2007 | 03:46 PM
klx300guy8's Avatar
Not true. I actually watched the mechanic the entire he removed the old and installed the new. In fact I witnessed him pull the FCA from the Mopar box. I would guess they are trying to screw you over.
Old Jan 3, 2008 | 08:58 PM
ddt111's Avatar
Sorry i havent posted in a while. My truck is at dealership now. After 3 hours of diagnostics and $629 later, it was the FCA. Hope this is helpful to someone else. Maybe save you a few $.
4969joes
Mar 28, 2010 05:26 PM
tjohnson
Mar 11, 2005 09:35 AM
PK
Feb 15, 2005 07:13 PM
ejb
May 12, 2003 10:24 AM
