Sensor maybe?
Old Jan 1, 2003 | 04:35 PM
rich's Avatar
Re:Sensor maybe?
My 98.5 has done that to me 3 times. I still haven't figured out what does it. I'm trying to find an inexspensive code reader for the truck. Haven't had any luck so far. If you find out what caused it let me know and i'll let you know if i learn something. My does it just like you said going fine dies for a few seconds then comes back on with the check engine light.
Old Jan 1, 2003 | 08:14 PM
chuck3's Avatar
Re:Sensor maybe?
Wonder if it could be the CKP sensor, just had mine replaced as it was going bad and check eng light came on. Was told it could cause fueling problems. ???
Old Jan 1, 2003 | 08:19 PM
danlit's Avatar
Re:Sensor maybe?
Can`t you check the codes by turning the key on &amp; off 3 times , leave it in the on postion and watch the odo?<br> Danny
Old Jan 1, 2003 | 08:28 PM
drecu's Avatar
Re:Sensor maybe?
I had the same problem, it was the crank position sensor CKP it casts about $35 form Cummins!<br>BTW I also replaced the CPS Cam Position Sensor at the same time.<br><br>DRecu!
Old Jan 1, 2003 | 08:30 PM
chuck3's Avatar
Re:Sensor maybe?
[quote author=danlit link=board=13;threadid=9062;start=0#87145 date=1041473975]<br>Can`t you check the codes by turning the key on &amp; off 3 times , leave it in the on postion and watch the odo?<br> Danny<br>[/quote] <br><br><br> No codes came up for me, had to have it scaned. ???
Old Jan 1, 2003 | 09:29 PM
drecu's Avatar
Re:Sensor maybe?
Chuck3 Hold the trip button &amp; thurn the key to the on position &amp; then let go of the trip button &amp; it will read out in the odo.
Old Jan 2, 2003 | 12:02 PM
AlpineRAM's Avatar
Re:Sensor maybe?
BBD<br><br>I think that the 1693 is an overboost code resulting from your box. <br>The other one looks more serious to me. But checking on all the connectors on the pump could help. <br><br>HTH<br><br>Good Luck<br><br>AlpineRAM
Old Jan 2, 2003 | 04:55 PM
phox_mulder's Avatar
Re:Sensor maybe?
The 1693 code is just telling you that a code is also stored in the ECM as well as the PCM.
There are a couple of OBD II sites that misrepresent that code.
I have a link at home to a good site I'll have to edit this post later to include it.
And here it is. http://www.batauto.com/chrysler/
I noticed if you just go to their OBDII section, the 1693 is a turbo control circuit which is incorrect.
It is correctly identified in the Chrysler specific section.
phox
Old Jan 2, 2003 | 05:20 PM
chuck3's Avatar
Re:Sensor maybe?
[quote author=drecu link=board=13;threadid=9062;start=0#87170 date=1041478159]<br>Chuck3 Hold the trip button &amp; thurn the key to the on position &amp; then let go of the trip button &amp; it will read out in the odo.<br>[/quote] <br><br><br> Thanks, I did not know that. ???
Old Jan 2, 2003 | 07:46 PM
drecu's Avatar
Re:Sensor maybe?
[quote author=BigBlackDodge link=board=13;threadid=9062;start=0#87339 date=1041528502]<br>Pulled up codes 1693 and 1765<br><br>Turbo Charge control circuit malfunction<br>Timing Solenoid malfunction<br><br>Any ideas anybody?<br>[/quote]<br><br>Same codes as my truck had, it's the CKP.<br><br>DRecu!
Old Jan 2, 2003 | 07:59 PM
chuck3's Avatar
Re:Sensor maybe?
[quote author=BigBlackDodge link=board=13;threadid=9062;start=0#87252 date=1041512985]<br>Are bothof these sensors located on the block behind the sarter?<br><br>If not where.<br><br>thnx<br>[/quote] <br><br><br> The CKP is located right below the lift pump.<br>
supr
18
May 21, 2007 09:29 AM
Gene007
0
Feb 26, 2006 04:31 PM
tyssniffen
Feb 11, 2006 01:28 PM
Booost Almighty
Jan 1, 2006 01:41 PM
wildmann
Aug 14, 2005 07:15 PM
