Rebuilt VP44 strange problem
Old Nov 17, 2007 | 07:54 AM
grzpdlr's Avatar
Just had a rebuilt VP44 put in my 2001 Dodge 2500. Wouldn't start. The guy that installed it said it was because my FASS was over pressuring the IP and he would prove it. He said remove the FASS fuse while I crank it, then put it right back in when it starts. Started instantly. I have 21 psi on my 150 FASS. Now I either have to put a FASS disconnect switch in the cap for starting. (my wife is gonna hate that!) Or try to cut the return spring down to lower the pressure. The mechanic said this was a problem with all rebuilt VP44, can this be right?
Old Nov 17, 2007 | 12:55 PM
grzpdlr's Avatar
Update
Found another "softer" spring for the FASS, fuel pressure now 15 psi, truck starts first crank!
Old Nov 17, 2007 | 02:13 PM
Timmay2's Avatar
Not a problem with all reubilt, but a problem with all Vp44 period. They are only designed to operate within a certain psi range.
More is not always better.
Glad you found a good solution.
Old Nov 20, 2007 | 11:15 PM
grzpdlr's Avatar
2nd Update
The problem is still returning intermittenly even at 15 psi FASS fuel pressure. Same thing as before, remove fuse from FASS, starts right up.
Got a work around I'm gonna try tomorrow. Will get 12 V + from the pwr windows circuit (windows stop when you crank).
Question is, I read somewhere that an ECM re-program would solve the problem. Anyone know anything about this?
Old Nov 21, 2007 | 03:54 AM
AlpineRAM's Avatar
The ECM gives a 50% duty cycle signal on the LP pigtail while cranking.
You can either use a relay and a circuit consisting of a diode, a capacitor and a resistor to drive the relay for your fass or use some source that's deactivated while cranking- but you have your fass running when you have the engine off but ignition on.
HTH
AlpineRAM
Old Nov 21, 2007 | 07:23 AM
grzpdlr's Avatar
Thanks AlpineRAM,
My current setup uses the ECM pigtail signal to activate a relay, but I'm just talking about getting the pwr from the window motors circuit instead of the battery. Won't this work?
Old Nov 23, 2007 | 03:59 PM
mrclean's Avatar
Originally Posted by grzpdlr
Thanks AlpineRAM,
Yes, that will work. In fact, that's a fix that the FASS people will tell you about. You're not the only person to experience that problem.
Old Nov 23, 2007 | 09:40 PM
grzpdlr's Avatar
Thanks mrclean, I have read on the FASS site this is due to a damage diaphram. Could this be the case on a new rebuild?
It did work by the way.
Old Nov 24, 2007 | 03:33 PM
AlpineRAM's Avatar
The only thing I dislike about the window fuse solution is that in case of an accident that stops the engine the fuel pump won't be turned off.
AlpineRAM
Old Nov 24, 2007 | 05:51 PM
grzpdlr's Avatar
Got that covered, the OEM wire to the lift pump energizes a relay, the window up/down wire is then through the relay supplying the 12 volts to the FASS.
Resbum
Oct 31, 2012 01:13 AM
Chass
0
Jun 19, 2011 02:05 PM
RAM123
Nov 13, 2009 06:52 PM
gwatson
Jul 24, 2009 05:18 PM
cmweber
Apr 23, 2005 04:36 PM
