Radiator Drain Plug
Old Jul 16, 2005 | 01:04 PM
kevinn's Avatar
Question Radiator Drain Plug
Can someone tell me how the radiator drain plug works on an '02 Dodge? Does the plug come out all the way or just partially? Any good instructions on how to change out the fluid would be helpful as well.
Old Jul 16, 2005 | 04:46 PM
infidel's Avatar
It will come out all the way. Turn counter clockwise while pulling.
Best to have a replacement o-ring for the plug or another rig to go get one.
A search here for change coolant will give you tons of info.
Old Jul 17, 2005 | 08:18 AM
Stamey's Avatar
It's weird. You have to turn a 1/4 turn, then pull it out while turning about 1/4 turn. I found it makes less mess if you stick a hose onto the nipple and run it into a bucket. This is very helpful since you will probably need to be under there with pliers trying to pull out on the petcock when turning. I couldn't pull it with my fingers.
Chris
Old Jul 17, 2005 | 10:40 AM
kevinn's Avatar
Thanks. I was able to get it to come partially out and it took a while for it to drain. Just as an FYI, the 180 temp thermostat makes a big difference. It no longer even gets up to the 190 line and stays just below it. I also can't believe how much junk there was on the radiator. I thought it would be cleaner since the intercooler, ac condenser and transmission cooler sit in front of it.
Baja
Aug 13, 2008 10:22 AM
klx650a2
Jan 10, 2008 12:08 AM
laker
Aug 4, 2007 08:53 PM
gsdog1
Aug 1, 2007 05:04 AM
timcasbolt
Jul 7, 2007 12:40 PM
