Oil and water don't mix
Old Feb 17, 2003 | 05:38 AM
wanadieseltoo's Avatar
I am trying to buy a 97 CTD 1T 4x4. When I drove it the cab didn't get hot but the motor did. After checking under the hood I found gray pasty oily crap in the radiator. Uh oh. :'(<br>The truck ran like a scalded dog. How do I know if its a head or block or cooler or what else???? If you go to the *********** they would charge a fortune just to look at it.
Old Feb 17, 2003 | 05:55 AM
Smokee's Avatar
Re:Oil and water don't mix
wanadieseltoo<br>...and you should definitely get one. With the engine running, were there any bubbles in the rad? Were the radiator hoses hot? Was there contamination in the oil?<br>Sure sounds like a head gasket.<br>george
Old Feb 17, 2003 | 06:11 AM
The radiator was &quot;belching&quot; out gray pasty crap and large bubles in it. Not small. The hoses were not hot.
Old Feb 17, 2003 | 06:13 AM
berner's Avatar
Sounds like somebody might have put Barsleak in the rad. It will cause your antifreeze to look cloudy and will plug up your heater core if you use too much. Changing a heater core in these trucks is not an easy job. Just my opinion but I'd be looking at a few more trucks before I bought.
Old Feb 17, 2003 | 12:18 PM
Dieseldude4x4's Avatar
Echo what berner said. You could be getting a bag of worms there unless you are getting a very good deal on it.
Old Feb 17, 2003 | 09:36 PM
Well,, wanadieseltoo is now gotadieseltoo. Yep I bought it. Now all I need is a block, a new radiator, pitman arm, intake tube, and the cruise control fixed and I'll be on my way. Thanks for the advice guys.
Old Feb 18, 2003 | 03:01 AM
ProspectorTim's Avatar
[quote author=wanadieseltoo link=board=13;threadid=11069;start=0#105901 date=1045539405]<br> ...Now all I need is a block, a new radiator, pitman arm, intake tube, and the cruise control fixed and I'll be on my way. .. [/quote]<br><br>That is ALL it needs? LOL, you got the wrong nickname; shoulda been wannadieselBAD! <br><br><br>Congrats on the &quot;new truck&quot;; hope it works out for ya!
Old Feb 18, 2003 | 05:56 AM
Good luck with your truck. Once you get it right, you will enjoy it for sure.
Old Feb 18, 2003 | 10:08 PM
7g under loan value. I can put a little in it!!
Old Feb 19, 2003 | 06:41 AM
I figured you were getting a decent deal on it.<br>Let us know how the project goes.
Old Feb 19, 2003 | 07:02 AM
AlpineRAM's Avatar
WANNADIESELTOO: Maybe you cold get away with o-ringing block and head (if there are no cracks in the head or block) <br>Ths would be a good base for the 2 new turbos you'll have to install.<br><br>AlpineRAM
Old Feb 19, 2003 | 07:57 AM
Redleg's Avatar
You know, all that money into a new head you really should take care of it by getting a 3 piece exhaust manifold. Hate to repeat the problem.
Old Feb 19, 2003 | 08:58 AM
Ya if this thing runs any stronger after I get the oil out I'll need to install another seat belt. <br>Hey I don't see any of you Rams using the electronic monitors. Are they not reliable or what? I want guages (or readings) first thing.
Old Feb 19, 2003 | 09:01 AM
Ya redleg lets see what the problem is first. I hope your right and it is a gasket or worse__ head. I don't want to find out it is a hole in the block. If it is on tope the 3 pc is a good idea. Thanks for the suggestion.
HT3500
Competition / Pulls / OffRoad
Nov 30, 2007 12:00 PM
BC847
Sep 14, 2007 04:46 AM
Fergavs
Aug 22, 2007 10:21 PM
dieselfuelonly
Apr 9, 2007 12:03 PM
scottrod
Nov 2, 2006 04:20 PM
