Oil pressure gauge
Oil pressure gauge
Recently, I noticed that when I would turn on the key, the oil pressure guage would sometimes return to the pressure when the engine was last running. This happens about 1/2 the time. I am preparing to leave on a fairly long trip (3K miles) and will be pulling our 5th wheel. Yesterday, I took it to the "*******" as it is about out of warranty (97,500 miles). They thought it needed a new sender which they said would be $290 installed. Thought this was a bit much. I did get the mechanic to show me where the sender was supposed to be. I read the posts by 1032 a few days ago regarding not having any oil pressure and looked a the photos that Shovelhead had posted. I have the 99, 24-V engine, but the photo of that engine did not indicate which was the oil pressure sender. Any help or suggestions would be greatly appreciated.
Re:Oil pressure gauge
See if this helps. #22 is the oil pressure sender.<br>http://www.dodgeram.org/tech/dsl/mt_...l_sys_comp.htm
May have solved my problem, or at least for the moment. Located the general area of the sender and by feel found 2 wires connected to something on the block. I had left the key on and the gauge was showing normal oil pressure. I wiggled the wires and tried to move the plug they went into. After crawling down out of the engine compartment, the oil pressure now read 0 lbs. Started the engine several times and the gauge now seems to be working normally. Would have thought the mechanic at the "*******" would have done that for the $40 they charged me. They also charged me $40 to check the fuel pressure from the lift pump. They said it was OK with 14 lb at 3K rpm.
If the work ticket said check oil pressure guage, the "Mechanic" probably said "Yup....it's right there in the dash were it's supposed to be.......
GlennRMK
May 24, 2007 10:46 PM
Matt Lambrech
Jan 28, 2007 04:13 PM
Ripper01
Apr 11, 2006 09:10 PM
streetsmoker
Feb 22, 2006 06:47 PM
