No Power steering and hard brake pedal
Old Sep 4, 2007 | 01:12 AM
yamroamer's Avatar
Truck has been parked for a week,come to move it this morning,nearly shot me through the house wall.I had to stand on the brakes,as if the servo or what ever was not working.While reversing back relised the truck has lost its power steering,when trying to turn in the yard it just threw fluid out of the fluid reservoir filler cap.Any ideas please as to where to start trouble shooting.The downside to all this,is that yesterday I booked the ferry for next Saturday for a two week trip to France with the trailer,and if I cannot get it sorted the trip is off. Thanks in advance Van
Old Sep 4, 2007 | 05:10 AM
Rpainter's Avatar
The Power Steering Pump Runs The Hydrobooster No Power Steering No Brakes
Old Sep 4, 2007 | 05:30 AM
pupeperson's Avatar
Sounds like you need a new power steering pump or at least the one you have rebuilt.
Old Sep 4, 2007 | 02:24 PM
chariotdriver's Avatar
Coupler Gear between vacuum pump and ps pump
Check out the "fixinrams.com" website. If you shear the ears of the coupler gear you will end up with the exact symptoms you have. Hope this helps.
Old Sep 4, 2007 | 05:27 PM
yamroamer's Avatar
Thanks Guys for the info.Tried her out this evening and every thing is working fine.I will have a detailed look at her on Friday.Once again thankyou for the info. Van
Old Sep 4, 2007 | 10:53 PM
2500Ram's Avatar
Did you change anything??? If not DON'T wait until Friday... You more than likely have a failed power steering pump that's working again, been there done that own the t-shirt. You won't like driving let alone towing anything with no power anything. It's a common problem, I'd replace the pump just to be safe.
Good luck.
Old Sep 4, 2007 | 11:11 PM
mudman78's Avatar
The same exact thing happened to me about a year ago. I had it towed to work since I couldn't drive it with no brakes. When it came down off the flatbed, it was working again. It's been fine ever since. I never did find out what caused it.
Old Sep 5, 2007 | 09:49 AM
infidel's Avatar
Sometimes turning the wheel with the engine off will cause air to enter the system and air lock the PS pump. This also causes fluid to puke out of the top of the reservoir.
Problem cures itself.
Old Sep 5, 2007 | 04:01 PM
yamroamer's Avatar
Thanks for more info,up until Thursday I`m on fifteen hour shifts ,so the truck will have to wait while Friday.When I have serviced the truck to be honest I`v never paid any attention to the power steering,all the cars that I have owned and the six heavys I have operated over the last 25 years,have never given me any problems with the power steering so I have tended to ignore doing anything with the power steering system. Just started the truck tonight and the steering and brakes are normal,hopefully mine will be like Mudmans experience.When I said the truck has been parked a week,in that week it will have been shunted about the yard a few times,so Infidels comments hopefully might be pertinent to my truck.Thanks again Van.
Old Sep 5, 2007 | 06:06 PM
Dean Snow's Avatar
I've been through the same thing. Replace the pump.
Dargo
Jan 12, 2018 07:45 PM
hightops76
Dec 27, 2009 09:28 AM
moneytlks01
Oct 10, 2007 12:54 PM
capt.Ron
Mar 16, 2005 10:36 PM
Idaho Guy
Feb 25, 2005 10:01 AM
