New lift pump, still now preasure
Old Jul 14, 2007 | 11:17 AM
Pinkston's Avatar
Working on a 01.5 2500 HO 6 speed
We just put in gages and found the LP was not working. Put a new LP in this morning. It seems to be working fine, but has trouble building preasure. When we crack the line there is fuel coming out, but the guage does not build preasure. After going through this prosses a few times I get a good bit of air out and the pump builds 15 lbs. Close the line, bump the starter again and nothing, no more preasure. Fuel filter is new, all lines and fittings have been triple checked. It seems like it is still getting air in somewhere. I am sure the injection pump is on its last legs, if not already dead, but we should still see preasure at the gauge.
Any input or tips?
Old Jul 14, 2007 | 12:07 PM
Geico266's Avatar
Just drive it for a few days, the air will come out of the lines by itself and the pressure should stabilitze.
Old Jul 14, 2007 | 12:10 PM
Pinkston's Avatar
This is not on my truck.
No fuel preasure isolater.
The gauge line runs straight from the banjo bolt on the IP to the back of the gauge. The truck is getting air in the system some how just cant figure out how.
How difficult is the draw straw to get to?
Old Jul 14, 2007 | 12:17 PM
Pinkston's Avatar
That would be great if it would start.....
Old Jul 14, 2007 | 12:27 PM
monnshyne's Avatar
It's in the fuel tank EI the pipe inside. It may or may not have a filter bag on the end of it. Also make sure you don't have a pinhole in your supply line from the tank to your LP. Sometimes they rub a hole in them from vibration.
Mark
Old Jul 14, 2007 | 05:46 PM
Pinkston's Avatar
Got it running.
after alot of checking we everything seemed fine. We checked the preasure coming out of the lift pump going into the fuel filter. It was fine, 15 lbs no problem. This means it has to be the new filter or the line coming from the filter running to the injection pump. Replaced the line first...nothing. Pulled the filter out, 15 lbs of preasure. Hmmmmm... Went to Napa, told them the the situation and they exchanged the filter for another new one. Put the new on in and everything is fine, 15 lbs of preasure. The lift pump was no doubt bad, but all this other mess was because of the filter.
projectRam
May 14, 2004 09:02 AM
jt
Mar 22, 2004 07:36 PM
bcmopar1
Dec 30, 2003 07:12 AM
thumper 549
Oct 27, 2003 02:50 PM
kingofdodge7131
Mar 29, 2003 04:12 PM
