no oil preasure
Old Mar 21, 2004 | 08:36 PM
jt's Avatar
jt
no oil preasure
after starting my truck, I had been in a store for app. 30 min. When I pulled away the oil preasure dropped to 0 and the light warning came on. I checked the oil, it was full. When I re-started it, the gauge climbed, 15 seconds later it was back at 0. I did this 6 times or so and it then stayed up. I drove 4.5 hours it was fine. the next day on start up it did the same but was fine on the third start. Drove for 2.5 hours no problem.
My thoughts are it is electrical. Any thoughts?
James
Old Mar 21, 2004 | 09:26 PM
GSpeed's Avatar
How cold was it outside? What weight of oil are you using? The reason I ask is that the same thing happened to me at -40. I still had 15w40 in the truck at the time.If you turn on and off your ignition key you might find a code that indicates a low oil pressure condition.
Old Mar 21, 2004 | 10:13 PM
jt's Avatar
jt
engine was operating temp the first time it happened, second time it was -8'C outside.
James
Old Mar 22, 2004 | 10:05 AM
Nitro71455's Avatar
sounds like the sender may be going bad.... I'd take it in ASAP to have it checked out just to be on the safe side.
Old Mar 22, 2004 | 11:48 AM
bigblock2stroke's Avatar
I would put a mechanical gauge on it to make sure. If it is still under warranty (<100k miles) I would also take it in to avoid being blamed for driving it while you knew the oil pressure was saying zero.
Old Mar 22, 2004 | 03:39 PM
mymaur's Avatar
There is probably nothing wrong with the oil system, just something in the sending system. But a good point was made about getting it in to the dealer.
Old Mar 22, 2004 | 07:36 PM
spudman's Avatar
My 1999 has the same problem - diagnosed - oil pressure sensor - $280 - too steep for me! Works most of the time now - keeps getting better and better.
l jobb
Jan 31, 2008 10:27 AM
charliex25
Aug 11, 2006 04:35 PM
acook
Apr 9, 2006 03:22 PM
thumper 549
Oct 27, 2003 02:50 PM
kingofdodge7131
Mar 29, 2003 04:12 PM
