Oil Preasure
Old Mar 25, 2003 | 11:45 PM
kingofdodge7131's Avatar
Oil Preasure
Hey, I had my oil changed about 1000 miles ago, tonight i just happened to look down and the OP was up to the 3rd line, like around 80 or so what could of caused this? its sitting in the drive way for a while till i can figure this one out haha<br>thanks<br>nate
Old Mar 26, 2003 | 09:11 AM
Dodgezilla's Avatar
Re:Oil Preasure
Mine always stays at about 60 at idle and goes up to around 75-80 when I'm really pushing it. Did you use the correct weight of oil? I don't think it's anything to worry about. If it was too high it would have blown the oil filter gasket out..<br>One time Motorhead and I built a HP 360 engine for my 64 Valiant convertible and we put a Hi-vol oil pump in it and also bought a hi-pressure spring. Well we tried putting the retaining cap, which holds the spring in, in backwards to create more pressure. Well we fired it up and that needle on the guage flew all the way to the other side of the guage and then the oil filter gasket blew apart. Needless to say, I had a well-lubed chassis. I guess it is possible to have too much oil pressure..... ;D
Old Mar 26, 2003 | 10:05 AM
Olratlr's Avatar
Re:Oil Preasure
If you was running truck at highway speeds sounds good. ;D
Old Mar 26, 2003 | 02:27 PM
Re:Oil Preasure
aight, always sat at 40, pretty faithfully haha. but thanks for hte input ill check out the weight and what not <br>Nate
Old Mar 26, 2003 | 11:57 PM
NAIL BENDER's Avatar
Re:Oil Preasure
Was the engine cold? When cold your oil pressure will be higher.
Old Mar 27, 2003 | 02:29 PM
Hauler's Avatar
Re:Oil Preasure
My oil pressure runs just shy of 40 when warm, runs a little higher when pulling and much higher when cold. I run rotella oil.<br>Derek
Old Mar 29, 2003 | 04:12 PM
ET's Avatar
ET
Re:Oil Preasure
mine runs at the 3rd line all the time, even when the motor is off and the key is on ???. yes i think i have a problem with the sender or the guage. but it is great to have instant oil preasure
l jobb
Jan 31, 2008 10:27 AM
charliex25
Aug 11, 2006 04:35 PM
acook
Apr 9, 2006 03:22 PM
jt
Mar 22, 2004 07:36 PM
thumper 549
Oct 27, 2003 02:50 PM
