need help fast
Old Jan 24, 2006 | 09:13 PM
swdiesel's Avatar
need help fast
Friend installed a bullydog powerpup on a 2004 2500 6 speed and the powerpup was for a 2004.5-2005 and the truck will not statr and is stuck at a gas station. the powerpup will not let it go into recovery mode it says error in sector1
Old Jan 24, 2006 | 09:39 PM
99 cummins's Avatar
If he is at a gas station I would assume that means it drove for a while. Any idea if it was showing any symptoms while he was driving?
Old Jan 24, 2006 | 09:50 PM
swdiesel's Avatar
No hey did not drive it for a while he thought it would be a good idea to install it at the gas station
Old Jan 24, 2006 | 10:07 PM
99 cummins's Avatar
Freinds should not let friends drive while doing thoughtless things, Being politcally correct here I hope.
Old Jan 24, 2006 | 10:14 PM
bama's Avatar
round-about way of getting there,,but,,,,,,go to 3rd gen performance forum,,,,,scroll back to page 20.......problems with downloaders thread......scroll through to 04ctd reply and his link to his thread on his ordeal with bullydog .......best read on problem like youre having ive read on here...................bama
Old Jan 24, 2006 | 10:23 PM
RCW's Avatar
RCW
To get up and running quickly, disconnect and remove the fueling box you installed, and then leave the negative battery cables disconnected for an additional 20 minutes. This will default the truck's computer back to its OEM settings.
Reconnect the batteries and the truck should start unless you have permanently damaged the PCM.
Because the 04.5 and newer Cummins uses a totally different controller map to handle the different style turbo used on the later engines, the box you installed will not work.
Jim Lane
Dec 7, 2015 09:16 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
wwm
Feb 26, 2009 08:37 PM
Sam Turner2
Jan 11, 2008 03:32 PM
trik396
Mar 14, 2007 07:57 AM
