Need help with 93 ctd injection pump, need it fast!
Old Feb 24, 2009 | 12:10 AM
wwm's Avatar
wwm
My brother and i are building up a project truck, and today we got the 366 spring in, So my brother and his friends they are 16, they do it by themselves, and when they took it apart they didnt mark any on the timing marks. So now they truck will not start. So now i am going to have to take the pump off and tear it apart because i dont know where they went wrong. So does anyone know where i can get some instructions on how to tear the VE pump down and build it back with the right timing? Please need help.
Old Feb 24, 2009 | 12:12 AM
Alwaysworking's Avatar
alwaysonDTR
the govenor spring install is in the sticky, did they try holding the throttle down while cranking? assuming the fuel shut off solinoid is hooked up and working
Old Feb 24, 2009 | 12:16 AM
wwm's Avatar
wwm
what is the sticky and we held the throttle down on the pump while cranking, and also we bled the injector line and fuel sprayed out. and we turned the fuel shut off both ways, and still nothing
Old Feb 24, 2009 | 12:30 AM
alwaysonDTR
this in the thread in the sticky about installing the spring, top of the 1st gen fourm.
http://dens-site.net/Dodge_CTD/Gover...ing/index.html
Old Feb 24, 2009 | 12:55 AM
wwm's Avatar
wwm
okay what is the TPS connnector and AFC cover? Could the tps connector be the problem not being lined up right on that piece under it?
Old Feb 24, 2009 | 01:19 AM
alwaysonDTR
the should not affect it, did they remove the power screw to put the pump top back on?
if its not in far enough it wont run, because it has no fuel, but if its in too far it can runaway, if the coller is still on the power screw that should not be an issue. all th fuel lines hooked up?
Old Feb 24, 2009 | 08:39 AM
SkinnyBTN's Avatar
Look through the thread below and it should help you to understand a little more of whats going on with the pump and what folks are trying to tell ya.
Can you hear the shutoff solenoid click? You should hear it.
http://www.cs.rochester.edu/u/jag/vw...i/injpump.html
Old Feb 24, 2009 | 09:15 AM
Field_boss_cb's Avatar
Did they take the pump off the engine?
Old Feb 24, 2009 | 01:40 PM
wwm's Avatar
wwm
they didnt take the pump off no. There is fuel getting to the injectors we bled them to get the air out, so the solenoid is turning on and off, i havnt check to hear it yet, but if there is fuel going to the injectors it is turning on right. I dont know much about them so i dont know. And also they pulled that lever that pushes on the full power screw
Old Feb 24, 2009 | 03:38 PM
They probably got the throttle lever indexed too loose.
Old Feb 24, 2009 | 03:40 PM
wwm's Avatar
wwm
where is the throttle lever indexed
Old Feb 24, 2009 | 03:50 PM
The throttle shaft is splined to the throttle lever. They are probably a couple splines off.
Old Feb 24, 2009 | 03:56 PM
wwm's Avatar
wwm
but it would still start right?
No, if it's too loose it won't even start.
Old Feb 24, 2009 | 05:52 PM
wwm's Avatar
wwm
that little spline that the line up with those lines, we put it back on at the marks that look like 4 and 10 o'clock
