HELP, Codes need help fast!
Old Jan 11, 2008 | 03:07 PM
Sam Turner2's Avatar
06 CTD acts liek its running on 5 cylinders.
Codes P2149
0514
0513
0205
no mods stock truck. I havs looked them up already, can anyone diuagnose my problem?
Old Jan 11, 2008 | 03:14 PM
53 willys's Avatar
P2149-BANK 2 (CYLINDERS 4-6) SHORTED HIGH OR LOW
WHEN MONITORED
While the engine is running.
SET CONDITION
A misfire detected at cylinders 4,5, or 6 or any combination of cylinders 4,5, or 6.
POSSIBLE CAUSES
  • Other DTC's
  • High side driver circuit open
  • Low side driver circuit open
  • High side driver shorted to low side driver
  • High side drivers shorted low
  • Low side driver circuit shorted other low side driver circuit
  • Low side drivers shorted low
  • High side driver shorted to voltage
  • Low side driver shorted to voltage
  • Low side driver circuit shorted in injector harness
  • Injector
  • Injector harness
  • ECM
  • Intermittent condition
P0514-BAT TEMPERATURE SENSOR RATIONALITY
WHEN MONITORED
SET CONDITION
The ECM does not read a change in value from the sensor over time.
POSSIBLE CAUSES
  • Battery TEMP sensor
P0513-SKIM INVALID KEY ERROR
WHEN MONITORED
Key on
SET CONDITION
Invalid Key Code received from SKIM Module
POSSIBLE CAUSES
  • General network error
  • Key not programmed
  • Incorrect key
  • Incorrect VIN IN ECM or SKIM
  • Loss of communication between ECM and SKIM
P0205-INJECTOR #5 CONTROL CIRCUIT
WHEN MONITORED
SET CONDITION
When the injector current falls below a calibrated threshold.
POSSIBLE CAUSES
  • Pass trough connectors open
  • Fuel Injector
  • Injector harness open
  • High side driver harness open
  • Low side driver harness open ECM
any other info about the truck???
installed anything new lately???
Old Jan 11, 2008 | 03:16 PM
sootindiesel's Avatar
P0514 BAT Temperature Sensor Rationality
P0205 Injector #5 Control Circuit
P2149 Bank 2 (Cylinders 4-6) Shorted High Or Low
not sure what the 0513
Old Jan 11, 2008 | 03:20 PM
No, nothing new, 120K miles, Has done a smiliar thing before and we pulled over, drained the water trap, wiggled every connecxtion we saw and it carnked up and it ran good, not this time.
Old Jan 11, 2008 | 03:22 PM
no chip, not straight pipe,nothing, bone stock... Second owner, truck smokes like crazy when you hammer down on it, 6SPD, so it may have a set of injectors in it??? (good ole black smoke)
Old Jan 11, 2008 | 03:24 PM
53 willys's Avatar
I would try looking for a chafed connection some where....ECM plug?? injector plug?? something sounds loose or chaffed to me or a bad connection of some sort??
Old Jan 11, 2008 | 03:25 PM
Ok Thanks, will check out and report
Old Jan 11, 2008 | 03:28 PM
53 willys's Avatar
you are probably going to have to take it in so someone with a scanner can check it better....hows the oil level??
Old Jan 11, 2008 | 03:29 PM
53 willys's Avatar
do you have a volt meter that can do Ohms???
Old Jan 11, 2008 | 03:32 PM
dodgezilla04's Avatar
i have seen where the injector connectors(under the cover) have contacted the rockers, causing the short... just required a loosening of the retaining nuts for the wire lugs and position them so they cant touch anything metal.
Jim Lane
Dec 7, 2015 09:16 PM
exwrestler
Feb 5, 2010 09:34 AM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
mbenedict
Jul 21, 2007 09:19 PM
trik396
Mar 14, 2007 07:57 AM
