Is my clutch going?
Is my clutch going?
i have a 2002 with a 6 speed after i drive a while sometime the Clutch petal will become spongy and lose resistance and the truck wont go into gear. after a few seconds or almost a minute it comes back on is fine what coud this be ?
It is most likley your slave cylinder or maybe a master cyl. But if you would like to check if your clutch is going out put it in 4 or 5th and floor it if it goes your good if it reves up with out moving it going out.
how do i test wich one of those it is ?
thanks a ton for the info.
I haul with it alot. someone said the fluid could be shot is that a possible?
It doesnt feel like its slipping under load or anything like that just once in a while the pedal goes dead and it wont go into gear then i let it out the pedal comes back and its fine.
well thanks again .
well thanks again .
I just went through this in my '03 at ~150,000 miles. I'm not sure about your '02, but the dealer sells the Master and Slave as a connected unit. I think it was around $170 or so. Take out the old M/S and install the new as a unit.
The benifits are:
The benifits are:
- No guessing which is bad,
- You are not replacing one unit just to find out the other is what was bad,
- No bleeding necessary as it is a sealed unit (probably best benefit)
you could try syphoning out the clutch fluid in the resovoir and replacing with new fluid.
sounds like its got to much water in it. or just replacing the entire thing as a unit. i don't think they are sold seperatly on those trucks. but i mean try the cheapest method first.
You take the necessary bolts loose from each component slip the old out and slide new in place. Look at the new one over and can figure where bolts are. Buy as assembly from Dodge or aftermarket Southbend for few dollars more.
ok today the symtoms got alot worse. i not only couldnt get it into gear but there were times the pedal went dead and i couldnt get it out of gear i had to stall it out to get it to stop. push in the clutch and nothing would happen wouldnt disengage. still sound like the >cylenders ?
Take the two bolts out of the slave cylinder and pull it out. Under the dash, pull the plastic thingy (Technical term) off the pin that goes through the Master Cylinder rod and the pedal, then pull the pin out.
If you take the nuts off the Master Cylinder (under the brake cylinder) it will be difficult to work the MC out with that big bracket on it. So, leave the nuts on and just give the old MC a twist counter clockwise and it will come right out.
Pull the MC up and out and have the slave follow it out.
Installation is is in reverse;
.tuo ti wollof evals eht evah dna tuo dna pu CM eht lluP
.tuo thgir emoc lliw ti dna esiwkcolc retnuoc tsiwt a CM dlo eht evig tsuj dna no stun eht evael ,oS .ti no tekcarb gib taht htiw tuo CM eht krow ot tluciffid eb lliw ti (rednilyc ekarb eht rednu) rednilyC retsaM eht ffo stun eht ekat uoy fI
.tuo nip eht llup neht ,ladep eht dna dor rednilyC retsaM eht hguorht seog taht nip eht ffo (mret lacinhceT) yginht citsalp eht llup ,hsad eht rednU .tuo ti llup dna rednilyc evals eht fo tuo stlob owt eht ekaT
Back to my evening adult beverage of choice.
Ummmm... I ment that as plural, as in beverages.
rynojr4644
Mar 10, 2012 06:35 PM
Dodgezilla
20
Mar 11, 2008 08:29 PM
Sean Allan
Apr 7, 2006 01:00 AM
