low idle
Old Jul 16, 2009 | 08:03 PM
patpat paul's Avatar
low idle
ok time for dumb summer questions but having this problem with my 98 12v auto with new pump from industrial injection ildes at 850 out of gear 650 in gear and tries to die with a/c on just ajusted valves anyboby know if this might be a pump problem pump is 8 deg above stock #6 plate 191 delivery valves runs great but this little prob also it has new tranny with billet tourqe converter thanx for any help>
Old Jul 16, 2009 | 08:07 PM
Have you tried speeding up the idle?
Old Jul 16, 2009 | 08:11 PM
rre
to how high on the tach seems high right now maybe with the mods i need to
Old Jul 16, 2009 | 08:16 PM
As long as it's not trying to pull you through intersections when you are sitting at a light, speed it up. The tach is not real accurate at low RPM.
Old Jul 16, 2009 | 08:18 PM
re
hahahaha ok but should it idle high do u think the stout tranny could be draging the motor down? it does roll when i put it in gear right now but you are saying it shouldnt take off and shift into 2nd hahahahaaha
Old Jul 16, 2009 | 08:28 PM
Between the tight converter and the A/C compressor it's a lot of load. You might try tightening the governor springs one click if you have a GSK in there.
Old Jul 16, 2009 | 08:56 PM
umm here we go with my edit where is it and how do i tightn it are you talking about the star wheel
Old Jul 16, 2009 | 08:57 PM
i just kicked idle up to about 950 and drops to about 700 with a/c and in gear not bad not falling on its face anymore. lol
Old Jul 17, 2009 | 05:32 PM
Yeah, spec is 650 in gear with the A/C on so that's not too bad.
Not the star wheel, the governor spring retainers inside the pump.
Old Jul 17, 2009 | 06:32 PM
Dr. Evil's Avatar
Actually no, the spec is 750-800 rpm in gear with AC on:
http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm
rjm022
13
Jun 9, 2023 06:34 PM
FlaCracker
Oct 23, 2009 02:42 PM
Smokin'02
Feb 9, 2009 08:43 PM
Breck-Ram2500
Jun 2, 2006 07:47 PM
spitzair
Jan 24, 2006 03:42 PM
