blown turbo?
Old Jul 15, 2009 | 05:36 PM
qmlogan's Avatar
blown turbo?
had tst box turned to level 5, running about 65mph on the freeway, i got into it. after a few seconds heard a pop noise and had severe white smoke blowing from exhaust with lost turbo boost. truck seems to run ok but builds no boost and turbo housing is leaking oil badly. i can cloud out a city block with all the white smoke from the oil running into the exhaust. i don't have any experience with turbo issues. please help. thanks
Old Jul 15, 2009 | 08:00 PM
kevellis32's Avatar
Check all boots...intercooler boots and such. Also check all of the head bolts to make sure he didn't blow the head
Old Jul 15, 2009 | 09:33 PM
JFlory's Avatar
Either blew a head gasket or the turbo. Best way to check is to take the exhaust manifold and turbo off the truck and start it up. Be sure to put the oil feed line to the turbo into a can or something. It will make a mess real quick. If oil pours out of one of the exhaust ports then you've blown the head gasket. If not, then the turbo is shot.
Good luck.
Old Jul 16, 2009 | 04:09 PM
lovinCTD59's Avatar
Sounds like the turbo let go. Happened to me last year, almost to the date. Only my compressor wheel blew up in the housing...
Old Jul 16, 2009 | 06:35 PM
qmlogan's Avatar
took turbo off today. compresser wheel blew through housing. Anyone have a 351 turbo for sale?
Old Jul 17, 2009 | 08:58 PM
qmlogan's Avatar
picked up a 351 turbo off of a 05 today. so does this turbo just run without an wastegate on my 03?
RollinCoalSmoke
Mar 18, 2009 01:49 PM
Weston
Jun 27, 2007 05:27 PM
ellmannbru
Mar 28, 2007 09:48 PM
12valve
14
Feb 22, 2007 09:07 PM
Lsufan78
34
Jul 19, 2004 12:59 PM
