lost prime
Old Feb 11, 2009 | 04:29 PM
fire dude's Avatar
lost prime
Need help, lost the prime in a motorhome with a 5.9L. The question is the motorhome is in the driveway on a incline. I have tried everthing to get this primed. Does anyone think it being on a incline is part of my troubles. Can use your help?
Old Feb 11, 2009 | 06:44 PM
You have fuel at the injection pump? What year motorhome are we talking and how cold is it where you are?
Old Feb 11, 2009 | 07:52 PM
BigIron70's Avatar
Cummins Guru
What year? electric pump or mechanical? check fuel filter is there fuel in it? is there fuel in tank? Any codes?
Old Feb 17, 2009 | 11:58 AM
Panhead51's Avatar
Carefully, with one person cranking and one responsible person at the air intake with some starting fluid. While cranking give a very tiny shot of the fluid into the intake, the engine will catch and rev slightly, you'll probably have to do it about three times. Be very carefull with the starting fluid, it's not your motors favorite fuel and can definetely mess you up if use too much. But usually it's all it takes to get things cranking and primed again.
Old Feb 17, 2009 | 12:18 PM
smokeyram's Avatar
i read on hear about pressurising the fuel tank with a compressor. with air behind the fuel, it forces the fuel into the pump. You will have to do a search to find it, it was some time ago.
Old Feb 17, 2009 | 03:35 PM
rich's Avatar
we use this trick to prime all are diesel trucks big and small. get a rag and soak it in gas, hold the rag on the intake tube and have someone crank the motor. hold onto the rag cuz it will suck it up if you are not careful. works everytime and doesnt vapor lock the cylinders like ether does
Murphy85
Apr 7, 2009 02:07 AM
TNfarmboy
Aug 20, 2006 09:10 AM
Merle
Jul 4, 2006 08:49 AM
Merle
Jun 21, 2006 06:27 PM
smokeyram
Mar 28, 2005 02:33 PM
