Lift pump or ?
Old Apr 16, 2006 | 09:24 PM
2wheelsup's Avatar
Lift pump or ?
Hi all,
We just got back from a 2000 mile trip, thank goodness! On my first fillup, after about 350 miles, my fuel pressure gauge showed 5 PSI. After about 2 minutes it went back up to 10-12 range. No more problems until morning. Started truck-5 PSI again and about 2-3 min later back up to 10-12. Every morning, same thing and if I waited to get fuel until down to 1/4 of a tank I got the 2-5 PSI again until 2 or 3 min went by. It was almost like it had to build pressure in the lines or something.
Is the lift pump dying or might something else be wrong.
Only have 40,000 miles on truck.
Thanks,
Alan
Old Apr 16, 2006 | 09:38 PM
crobtex's Avatar
Sounds like it to me. I don't thing these lift pumps understand milage. At least mine didn't.
Mine would drop from 12 or so to about 2 or 3 all of a sudden. I could "pop" the go pedal and it would come back up for awhile. After the second one, I went with the FASS II.
Old Apr 16, 2006 | 09:44 PM
Geico266's Avatar
LP for sure. Believe what your guage is telling you.
Old Apr 16, 2006 | 09:47 PM
Floorman's Avatar
when is the last time you changed your fuel filter? mine acts funny when it is due.
Old Apr 17, 2006 | 06:56 AM
Bob H's Avatar
Check under the truck. The rubber supply line to the lift pump just slips over the steel line from the tank. They get loose just from vibration. Mine acted the same way. Two .89 cent hose clamps solved the problem over 10k ago.
Bob H
Old Apr 17, 2006 | 10:38 PM
2wheelsup's Avatar
Thanks for all the suggestions. I'll start with the supply line, change the filter and then go for the lift pump.
I'll let you know.
Alan
Old Apr 17, 2006 | 11:17 PM
inline6power's Avatar
better do the lift pump as well just to be safe. after 4 lift pumps and 4 injection pumps i pay very close attention to my guauge. it has never lied. now that i have the pusher pump, at WOT it never goes below 26psi and at idle its at 33. trust me, driving with a lift pump that only works a little will definetly kill your VP44.
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
