Leaking Fuel
Leaking Fuel
Went to change the fuel filter today on 92 W350, seen a couple drips of fuel, well put the new one on and now the fuel seems to be running out of the little 1/2 adapter where the filter screws on. When I took off the old filter I thought I seen that adapter turn a little but I wasn't sure and I tried to turn it back and it doesn't seem to move. What gives? Anyone else have this problem or know what the fix is? Thanx in advance.<br>Rich
Re:Leaking Fuel
Alright, I'm assuming that the adapter that I'm referring to is actually the fuel heater. How does it come off? Is there an O-ring that could have gone south?
Re:Leaking Fuel
Jumk Yard:<br>As I recall, there is an o-ring on the adapter (heater?) The filters used to come with an o-ring for this center piece, but I don't think anyone ever installed them so they quit sending them. I have several on my dipstick tube. <br>In any case, yes, there is an o-ring. I think I remember that the easiest way to change it was to remove the entire housing since the ring sits in a recessed groove.<br>I hope I am not confusing with my first gen.<br>george
Re:Leaking Fuel
Thanx for the help Smokey, when I spun the filter (someone put it on with a torque wrench set at 100 ft lbs.) the heater also turned a little, like a 1/2", anyhow cleaned the surface of the heater and under the intake where it mounts, a little bit of rust scale under there, put it back together with a light film of grease, spun the filter on, fired the old girl up, wooooo-hoo no leaks. Thanx again for taking the time to reply.<br>Rick
lilsuzuki4x4
Sep 1, 2011 01:50 AM
diablo1
Nov 11, 2008 10:30 PM
txasylum
Mar 22, 2008 02:47 PM
Gumby
Jan 24, 2005 01:15 PM
