Water in Fuel Idiot light
Old Feb 25, 2003 | 11:24 PM
MYTRNx3's Avatar
Ok - it came on while playing in the mudd today - so I drained the filter, refilled it with fuel, primed the lines again, and the dang idiot light is still on. After letting it run for a fet - it will go off, but then come right back on again... <br><br>Suggestions, Smart remarks???<br>
Old Feb 26, 2003 | 05:15 AM
Alan_Reagan's Avatar
Re:Water in Fuel Idiot light
You may have to pull the filter out and clean the WIF sensor. Facing the filter from the drivers side, you'll see a connector going into the housing on the bottom left side of the housing. Inside is the sensor. Carefully clean off the sensor and that should solve your problem.
Old Feb 26, 2003 | 06:19 AM
Dieseldude4x4's Avatar
I've also had water get in the plug where it hooks up to the filter housing and turn the light on. I would usually take the electrical plug apart and shoot some WD 40 in the connections and wipe that out just leaving a film in the connectors. It would go out every time. That thing is very sensitive to moisture.
Old Feb 26, 2003 | 10:06 AM
MYTRNx3's Avatar
Strangest thing - Catch this one... <br><br>The WIF was on when I pulled up home last night - get in it this morning - no light. Went to feed, drove around for about 30 minutes - still no light...<br><br>Hmmmmm - Now I'm puzzled!!!
Old Feb 26, 2003 | 10:39 AM
DieselDaze's Avatar
[quote author=MYTRNx3 link=board=13;threadid=11499;start=0#109343 date=1046275619]<br>Strangest thing - Catch this one... <br><br>The WIF was on when I pulled up home last night - get in it this morning - no light. Went to feed, drove around for about 30 minutes - still no light...<br><br>Hmmmmm - Now I'm puzzled!!! <br>[/quote]<br><br>It does indeed sound like you got a little moisture in the plug. <br>Once it sat over night, the moisture dried and the light went off.<br><br>Rich
Old Feb 26, 2003 | 11:07 AM
Yep, zackly what he said. It takes less moisture to set these things off that will fit on the head of a pin. As soon as it dries and breaks one leg of the circuit, out goes your light. Next time it comes on, break the connection and spray it and see if it doesn't go out after you double check the filter housing of course.
Old Feb 26, 2003 | 11:36 AM
MYTRNx3's Avatar
Thanks ya'll... It was definatley a fun experiance! And I promise that I'll take a whole bunch of pictures when it's dirty this afternoon - before I make a trip to the carwash...
Old Feb 27, 2003 | 11:44 PM
DuallyJeff's Avatar
Don't worry dude, it does that all the time. If I powerwash the underside of my truck or bring it through a car wash it goes on. It just needs some time for the water to dry off of it.
Old Feb 28, 2003 | 01:20 PM
Sootblower's Avatar
I have had this exact same problem after washing engine. On mine it was simply the 2-prong connector at the WIF sensor that is NOT water proof. Disconnect and wipe dry then coat with vaseline.
carwash
Jan 22, 2008 06:53 PM
tanderson2002us
14
Apr 14, 2006 08:53 PM
***gyro***
Nov 16, 2004 02:16 PM
Barry Smith
Nov 14, 2004 09:56 PM
dakar
Jan 28, 2004 07:58 PM
