Fuel leaking from fuel filter housing!
Noticed yesterday that, when the truck is running, I have fuel dripping from what looks like the fuel filter housing. For those who will ask, I had the filter changed 2 or 3 months ago, so that's not the problem. It's dripping about a drop a second, but at $2.11/gal I'd rather burn it instead of dropping it on the ground!! Has anyone else had this problem & what did you do to fix it?? Thanks in advance!
Did you try to tighten the top? Takes a 1 1/8 socket. If that doesnt work, unscrew the top, and check to see if the o-ring is in place or cut. New filters come with the o-ring so if theres a problem by a new filter.
BUFFALO_STEW
Dec 17, 2009 02:42 PM
royta
Sep 17, 2005 10:25 PM
