Canadian 24v Leaking Fuel From Top Of Fuel Filter Housing
Old Dec 6, 2009 | 02:17 PM
BUFFALO_STEW's Avatar
I Have Heard Of A Fuel Heater Delete Kit Which Is What I Believe Is Leaking. Not Sure If That Is What It Is Called. Need Help.
Old Dec 6, 2009 | 03:31 PM
SIXSLUG's Avatar
Check the O-ring on the cap, they get replaced with every filter change. Also the cap may be cracked, they are plastic and sometimes crack at the top where the hex is molded in. I believe the fuel heater is down on the side of the housing.
Kurt
Old Dec 6, 2009 | 04:01 PM
PVjimmy's Avatar
I recently had the same problem. In my case it was the result of accidently leaving the old O-ring on and adding the new one. The ring is black and so is the cap. After removing the two damaged ones and installing a new one, no more leak.
Old Dec 6, 2009 | 04:40 PM
Copenhagenjunkie's Avatar
No plastic cap on the 1998.5. It's leaking from the wires at the top which is common, most have used silicon or mayb jb weld to reseal.
Old Dec 6, 2009 | 05:56 PM
Thanks Copenhagenjunkie. My Dad Suggested That Too. I Just Wanted Some More Opinions Before I Went That Route. Have You Heard Of A Delete Kit For That?? I Live In Northern California And It Doesnt Get As Cold Here As Canada Where The Truck Was Manufactered. If I Can Just Eliminate It It Would Be Better For Me To Bypass It Than Have It Do It To Me Again. Thanks Again For Responding.. Happy Holidays!!!
Old Dec 6, 2009 | 05:59 PM
Hey Sixlug. Thanks For Responding. My 98.5 Has A Metal Cap And The Heater Wires Go Into The Top Through A Rubber(?) Grommet. It Is Leaking Around The Edges. Have You Ever Heard Of A Delete Kit For That?? Thanks.. Happy Holidays!!
Old Dec 6, 2009 | 06:01 PM
HEY PVJIMMY Thanks For Responding. My 98.5 Has A Metal Cap And The Heater Wires Go Into The Top Through A Rubber(?) Grommet. It Is Leaking Around The Edges. Have You Ever Heard Of A Delete Kit For That?? Thanks.. Happy Holidays!!
Old Dec 7, 2009 | 06:21 AM
I have not heard of a delete kit. I would not want to delete, 1 trip into cold climate could spell trouble. I would do a search here to see how others fixed that problem.
Old Dec 7, 2009 | 02:57 PM
Beast2B's Avatar
Cummins have a replacement grommet for it? Wouldn't be too tough to swap it out once a year during a filter change.
Old Dec 7, 2009 | 04:17 PM
Dr. Evil's Avatar
The only real "delete kit" Ive seen is a upgraded lift pump. Most of them have a filter and water seperator (and lift pump of course) taht attaches to the framerail. From there, you remove the OEM fuel filter housing.
I think the delete kit the OP is talking about is for a 12V.
Old Dec 17, 2009 | 01:36 AM
bigfish95971's Avatar
Check the fittings and bleed fitting on top of housing, and fuel lines in area.
Old Dec 17, 2009 | 01:29 PM
SIXSLUG's Avatar
Yeah, no prob. I didn't see that your truck was a 98.5 when I answered, it'll differ from my 01.5!
I'd keep the fuel heater in there if you're in NorCal. I wouldn't think it would make that big a performance difference taking it out, unless your racing or sled pulling etc.
Kurt
Old Dec 17, 2009 | 02:42 PM
Grider Pirate's Avatar
Earlier this week....
https://www.dieseltruckresource.com/...l-t259375.html
... and from 2006
https://www.dieseltruckresource.com/....html?t=123810
The hardest part is getting the red and black wires OUT of the connector to install a new $.69 o-ring. You will need to purge the air out after this work. Just loosen a Banjo bolt a LITTLE when you bump the starter. Otherwise you end up with a lot of fuel in the driveway. This is expereince talkin' here!
jcamron
Feb 2, 2010 11:35 AM
njforestfire
Sep 11, 2008 12:19 PM
Gumby
Jan 24, 2005 01:15 PM
joefarmer
Dec 20, 2003 03:42 PM
