Trans not locking up in 3rd gear correctly
Old Dec 15, 2009 | 06:43 PM
CTD2001's Avatar
So over the weekend i replaced the original batteries in my 01 Dodge, (almost 9 years old), anyways, the problem that is occuring now is that the trans does not lock up in 3rd unless under moderate/heavy accleration and RPMs over 2K. I have a lockup switch in the truck and i can lock the converter at any RPM in 3rd i want, but it should be locking up before 2k rpms. Every other operational component with the tranny is normal and lockup in overdrive is normal as well. (This is a DTT trans) I have been having sensitive throttle issues and an APPS reset has seem to cure that, but now the 3rd gear lockup is off. Its not a huge issue cause it can be controlled via the switch, but i like things to be operating perfectly. I reset the ecm tonight and that has helped some, not a complete cure though. Anyone have this symptom before or anything. Thanks for the time
Old Dec 16, 2009 | 05:41 PM
Big Boat Puller's Avatar
if the batterys were disconnected the ecm has to re learn stategic adaptivity. it needs several complete drive cycles to accomplish this. i dont remember all the requirements but start from cold, reach operating temps, mild accelaration, steady highway speed and so on, mine took like a week to start shifting the way it use to.
Old Dec 17, 2009 | 03:50 PM
CTD2001's Avatar
Interesting, its been a couple days since i reset the ecm, i have not driven it very far yet, less then hundred miles, so maybe i just need to give it more time. I really want to replace the APPS with a Timbos, but i have not convinced myself that my is completely bad yet. Thanks again
Pendo2006
May 26, 2006 07:09 PM
xp8103
Dec 25, 2005 09:45 AM
Zeddy
Apr 18, 2005 11:21 AM
cantfindaname
Aug 13, 2004 10:44 AM
Big Rich
Aug 1, 2004 10:50 AM
