Leak from bellhouse
Old Jul 24, 2011 | 09:18 PM
Jake Morozko's Avatar
Leak from bellhouse
On my way to CA and have about two more hours. I stopped to get fuel and noticed a clear liquid (maybe clutch fluid) pouring out from what I can tell my bellhouse. turn the truck off and nothing soon as the motor turns over a steady stream. any ideas?
Old Jul 24, 2011 | 10:25 PM
torquefan's Avatar
If the slave cylinder was leaking clutch fluid it wouldn't care if the engine was running or not, also its reservoir is very small and you wouldn't get a steady stream for very long, so I think you can rule out the clutch hydraulics. Double check the fluid level in the clutch reservoir to be sure.
My guess would be a fuel leak from the fuel return hose that runs across the top of the bell housing on its way from the engine. (I am assuming your truck is a 94-98 12 valve.) The hose is hard to see but if you lay on top of the engine and look at the rear of it, you can see the pressure and return hoses. The return is known for weathering and leaking.
You'll need about 18" of 5/16" diesel-resistant hose, and two fuel hose clamps, if this is the case. And sorry, it's a bugger to change.
Old Jul 25, 2011 | 02:02 PM
I found the leak. It was one of the lines running across the top. Small section of aluminum tube rubbed down making a tiny hole. Thanks for the help!
Old Jul 25, 2011 | 09:20 PM
torquefan's Avatar
You're welcome. Glad you found it.
george7941
Nov 28, 2009 09:28 PM
superdiesel9
Oct 25, 2009 07:56 PM
beewize
Apr 20, 2008 08:31 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
