Small Drip of trany fluid @bottom bellhouse
Old Apr 20, 2008 | 03:05 PM
beewize's Avatar
Is this normal for any trany fuild to appear on bottom of bellhousing. what is the best way to check trans fluid level
Old Apr 20, 2008 | 03:12 PM
Blueboy's Avatar
trans
Park on level ground, start truck and let run while you check.
Old Apr 20, 2008 | 03:17 PM
beewize's Avatar
thanks what about any fluid on the small cover plate of the bell housing. there is a small drip flange "molded" into the sheet metal. Is anything at all normal, fluid that is to appear at that point and why
Old Apr 20, 2008 | 03:21 PM
bob4x4's Avatar
I doubt it is trans fluid..........more likely orange coolant seeping out of the heater hose to tube connection.Tighten up the clamps a bit.
Bob
Old Apr 20, 2008 | 03:24 PM
Spooler's Avatar
He forgot to tell you to check the tranny fluid with the tranny in neutral while truck running. Yes, it's probably coolant from the right hand side back of the motor heater hoses. Tighten or reposition the clamps.
Old Apr 20, 2008 | 03:27 PM
beewize's Avatar
thanks again. Im going to go check it out right now
Old Apr 20, 2008 | 03:33 PM
beewize's Avatar
Well you were right on!!!!!!!!!!!! lokin up alittle higher i could see drip on hearter hose Awsome help
Old Apr 20, 2008 | 08:18 PM
ptgarcia's Avatar
Mine leaked a bit out of the inspection plate after having the tranny serviced. I just tightened the bolts a bit and it stopped. It makes me wonder though, should any fluid be coming out of there?
Old Apr 20, 2008 | 08:31 PM
no_6_oh_no's Avatar
No, generally that is not a good sign. Howere, IIRC the vent is in the bell housing area and if it gets overfilled or churned up it will vent into that area and drip out the inspection plate. As long as it quits your good.
BearKiller
Jul 11, 2022 02:43 PM
Jake Morozko
Jul 25, 2011 09:20 PM
dslpwr81
28
Jan 26, 2009 09:08 PM
b4wheeler
Apr 18, 2007 03:54 PM
BearKiller
Feb 15, 2007 10:39 PM
