Help with rad drain.
Old May 21, 2008 | 03:47 PM
jlbrown's Avatar
Just drained my coolant so I could replace it, now drain will not close. Used my fingers to loosen the drain but when I went to close it its just spins. Surely it not that fragile. Anyone have this problem.
Old May 21, 2008 | 03:58 PM
high bid's Avatar
It shouldn't be. I drained mine last month. Maybe the threads aren't catching...push it in when turning it right.
Old May 21, 2008 | 04:10 PM
timcasbolt's Avatar
Read this thread to see if it helps: https://www.dieseltruckresource.com/...n+plug+problem
Old May 21, 2008 | 05:03 PM
jlbrown's Avatar
Thanks guys. I'll try again tomorrow.
Old May 21, 2008 | 05:18 PM
Bad Ramer Jamer's Avatar
They break real easy. You can get a new one at the dealer, or any of the cheapo auto part's. You will have to dig out the old insert that the plug screws into. You have to use a pair of needle nose, and break the old one to get it out.
Once you get the new one, you will see how to do it.
Old May 21, 2008 | 06:02 PM
A picture's worth a thousand word's.
The piece on the left snap's into place inside the radiator. Then you screw in the other piece.
Old May 24, 2008 | 04:15 PM
jlbrown's Avatar
Thanks for everyone's help. I pulled the draincock out and although I had blown it out with air it still tured out to be some crud stuck in it. Cleaned it out and it worked like a charm.
thrashingcows
Nov 12, 2011 01:51 AM
klx650a2
Jan 10, 2008 12:08 AM
ratsun
Oct 18, 2006 09:57 PM
wooff
May 1, 2003 11:22 AM
Extreme Diesel
Dec 11, 2002 10:34 PM
