HELP! Clutch Bleeding
Old Apr 14, 2004 | 10:01 PM
Truckracer's Avatar
Unhappy HELP! Clutch Bleeding
My clutch pedal was depressed while the slave was hanging in the air. We were installing a new clutch.
It pumped the piston out of the slave.....
How can I refill and bleed this system? It's a new setup, less than 3 weeks old, so throwing it away is not an option.
Old Apr 14, 2004 | 11:55 PM
infidel's Avatar
Never done one on a Ram but on other rigs the only way was to hang it up straight vertical, slowly add fluid and let it sit overnight to let the bubbles rise to the top.
Old Apr 15, 2004 | 03:31 AM
Dieseldude4x4's Avatar
We just replaced the one (whole system) on my truck out at Forest City Diesel and I think we left the slave cylinder hang from the master cylinder in a vise and just pumped the master slowly till all air was gone. It is a PITA but worked well.
Old Apr 16, 2004 | 08:53 AM
Truckracer's Avatar
Thanks for the replys.
After trying a couple of methods we were able to bleed it and got it back to "normal".
Denny
Old Apr 17, 2004 | 09:35 AM
bwat4's Avatar
Truckracer,
I changed out my clutch as well and have the same problems as you. What were the other methods you tried that worked?
So far nothing I've tried works.
Thanks
Old Apr 18, 2004 | 02:33 PM
Stamey's Avatar
As I understand it, these slave cylinders are "self" bleeding, meaning you just have to pump it until the air is out of there. Have you tried that, bwat4? Is it not working?
Chris
Old Apr 19, 2004 | 06:49 AM
bwat4's Avatar
Been pumping it alot. Three weeks worth in fact. Including driving.
It doesn't seem to want to get the air out of the system.
Old Apr 19, 2004 | 08:40 AM
Rammin On's Avatar
Pull the M/S cylinders off ... and bench bled the system ... then reinstall
madavisks
Dec 11, 2006 02:10 PM
Mr_Mopar
Dec 7, 2006 06:50 AM
heavyboostin
Nov 20, 2006 07:45 AM
d2a2
Oct 29, 2005 01:09 PM
cethane
Feb 26, 2004 02:24 PM
