Front differential vent line
Old Jan 23, 2007 | 10:31 PM
Art Shiver's Avatar
Angry Front differential vent line
Yesterday I had a Revtech 2" leveling kit installed along with a new set of tires. Today when I got home from work I realized that the front differential vent line was hanging underneath the truck. I looked to no availl as it got dark. I have it tied up but would really like to install it in the proper spot. Can any help?
Thanks in advance.
Old Jan 23, 2007 | 11:03 PM
53 willys's Avatar
so is it hanging off the truck or the axle?
if it hangs from the truck then there should be a vent nipple on top of the diff/axle some where.
if it hangs from the axle it should be tied up in the engine compartment back by the fire wall, I think??? could be by the drivers side battery too.
I just cant remember for sure.
Mark
Old Jan 24, 2007 | 12:07 AM
Crimedog's Avatar
Mine is up by the pass side of the firewall. It has a zip tie on it though so this may not be the right spot.
Old Jan 24, 2007 | 06:43 AM
Art Shiver's Avatar
It was hanging from the differential down to the ground.
Old Jan 24, 2007 | 09:05 AM
berner's Avatar
If I remember correctly, it clips onto the inside of the passenger side wheelwell . I'm at work so I can't check right now. Maybe someone else will verify it.
Old Jan 24, 2007 | 09:33 AM
PaulDaisy's Avatar
Why don't you get a longer tube and tie it up as high as you can anywhere inside the engine compartment, as long as it is not tight as to pull off when the axle moves? This way when you cross that 4' deep river you won't fill the differential with water.
-P
Old Jan 24, 2007 | 10:00 AM
infidel's Avatar
Most of them I've seen are under the factory airbox a little towards the firewall.
Old Jan 24, 2007 | 10:19 AM
Art Shiver's Avatar
Thanks, I will keep looking.
Rocky
Jan 16, 2011 08:31 AM
bigfoot
Jan 1, 2010 02:22 PM
97catintenn
Aug 7, 2009 08:23 PM
Tiara3100
Jan 14, 2008 10:06 AM
PsRumors
Mar 2, 2006 06:44 AM
