Front Differential Vent Tube
Old Jan 15, 2011 | 11:55 AM
Rocky's Avatar
Front pinion seal was leaking so before I changed it I wanted to make sure the tube wasn't clogged, when I was looking for the tube all I found was a red plastic cap on the fitting. I've owned it since new and I didn't put in on so it either came from the factory that way or the undercoating place I take it to did it. Just want to make sure this is not how it should be and now how do I fix it?
Just get some hose and run it from the fitting?
Where should I route it?
Does it need to have a special valve on the end?
Where can I buy one?
Old Jan 15, 2011 | 02:24 PM
15 Digger's Avatar
Should have a hose that runs up high in engine compartment. If you cross water higher than vent it will pull water into axle.
Old Jan 15, 2011 | 02:40 PM
CD in NM's Avatar
I lengthened my vent tube to get it higher and put a small breather filter on it, that way it's not getting dirt into the axle like the factory cap/breather allows.
CD
Old Jan 16, 2011 | 08:31 AM
Rocky's Avatar
Bought some tubing from the parts store and ran it into the engine compartment. I really think when they put the axle on at the factory they never took the cap off and ran the vent tube.
MadDog01
Mar 29, 2020 08:17 AM
Dean Snow
Sep 21, 2007 01:18 PM
Art Shiver
Jan 24, 2007 10:19 AM
moparlvr
Jan 23, 2004 09:40 PM
Commatoze
Apr 2, 2003 12:53 PM
