fan clutch or thermostat
Old Jul 19, 2003 | 02:36 AM
figure_9_pro's Avatar
Re:fan clutch or thermostat
I had the same problem on mine, got up to 230 pulling hills, and thought it was the fan clutch and/or the t-stat. It turned out to be oil vapor coming out of the breather bottle was being blown onto the radiator by the fan and then every piece of dust, dirt and debris that tried to pass through was caught by the oil. I pulled the radiator, held it to the sun and saw no light!
I spent almost 1 hour with degreaser and a pressure washer to get it clean, reinstalled it, relocated the vapor bottle away from the front of the engine and now I have yet to see 190 on the temp gauge where it used to sit just over 190 all the time.
Old Jul 19, 2003 | 02:43 AM
BigBlue's Avatar
I may end up doing that with mine. Mine has been going over 190 for a while now and it's really starting to bug me.
Old Jul 19, 2003 | 07:41 AM
RickCJ's Avatar
Get the 180 that's what should be in there from the factory, yes the new number is 3954194, it's Caltherm brand, better than Stant and cheaper. 180 should be marked on the thermostat.
Old Jul 19, 2003 | 01:33 PM
deerelover's Avatar
Being a &quot;new kid on the block&quot; I am amazed at the replies and help that I have received.<br>I will be checking this forum quite often.<br><br>Thanks for all the help.<br><br>Jim
Old Jul 20, 2003 | 10:03 AM
thumper 549's Avatar
flushing the rad dose not mean you on pluged it if it has a problem. <br> ez way to test-unhook from eng. plug all openings.<br>fill up.pull the plug on the lower hose and it<br>should gush out, no slow stuff here.anything less is a prolem .<br>thats a simple rad do it youself flow tast-file it.<br>Of course have cap off when you do this.
Old Jul 20, 2003 | 10:58 AM
DF5152's Avatar
u can check ur fan clutch by holding a piece of paper in front of the rad if it get suck up tight the clutch is working. i usually do this infront of the grill its a better measure of how well the clutch is working..
Old Jul 21, 2003 | 10:49 AM
hippie's Avatar
I have a 93 D350, and I just had the radiator rodded out , put in a new thermostat part # 3802273 then replaced the antifreeze with Texco extended life antifreeze and I used distilled water. The distilled water will keep the sedament from building up in your radiator. I haven't had a overheating problem sence.. I pull a 30' fifthwheel trailer. ;D
Old Jul 24, 2003 | 05:39 PM
awmasparky's Avatar
Thermostat, just had mine done. Fixed the problem, but now it runs much cooler 175 or so.
Old Aug 6, 2003 | 03:33 PM
ruben's Avatar
Hi,,,
I have the identical overheating problem with my Dodge, if you do
find a solution please let me know.
Ruben
Old Aug 6, 2003 | 04:07 PM
QUICKMCSS's Avatar
My 12v wont even hit 190* whats the problem?
Bookshelf
May 30, 2009 01:17 AM
jrs_dodge_diesel
Sep 28, 2007 11:38 AM
MmmDieselFumes
Sep 27, 2007 06:44 PM
MmmDieselFumes
Sep 27, 2007 03:04 PM
big jimmy
Jul 7, 2006 01:33 PM
