Engine stumble after Superchips install
Old May 10, 2006 | 05:56 PM
ramman21921's Avatar
Installed my superchip microtuner today on safe-tow. wide open run it will not stumble. when accelerate at about a 1/4 pedal it stumbles at 2200 RPM and then comes right back. What could cause this? I have not gotten a EGT gauge yet and don't plan on running hard until do you think I am safe to even have it programmed in truck? I have a hand held infra red temp gauge i planned on checking the pipe 6" below turbo what temp difference would be from internal and external?
Old May 11, 2006 | 09:13 AM
displacedtexan's Avatar
Have you checked for codes? Are you getting any? 0216?
Maybe go back to stock, quick test drive, if it's gone, reload Superchips?
(That is just a guess)
Old May 14, 2006 | 08:48 AM
high country's Avatar
2200 is about when the tuner would be fueling the hardest.....you have a fp guage right?
Old May 14, 2006 | 10:14 AM
roysleight's Avatar
Hey Ramman, did you try it back on stock and/or reprogram. Any change? I for one am curious what happens.
Old May 14, 2006 | 11:38 AM
No FP Guage yet. I noticed this stumbling the first day I installed did it twice and not when I was running hard just taking off from light gradually. Since then it has not done it again which is a good thing. I will keep you posted on any more stumbling.
Old May 14, 2006 | 05:01 PM
Just checked for codes through odometer. Had a 1694,1693, and a 0216 this truck only has 55,000 miles on it if the injection pump is ready to go out I would classify this truck as a piece of sh##! Any suggestions? could the Superchips possibly caused these codes? Tomorrow I will unload the Superchips and check for codes again.
Old May 14, 2006 | 05:23 PM
Just cleared codes will run tomorrow to see if codes come back.
Old May 14, 2006 | 11:51 PM
sorry for your loss.
Old May 16, 2006 | 06:07 PM
Thumbs up
Cleared codes and two days running with no codes coming back. Going to make a Beach Trip this weekend hope everything is OK.
pwrtripls1
Feb 9, 2012 08:46 PM
MICHAEL J
Jan 31, 2012 07:28 PM
safirenfish
Dec 3, 2010 11:21 AM
HOdiesel80
Mar 22, 2007 12:19 PM
