Engine removal
Old Apr 7, 2007 | 09:38 PM
kcredneck's Avatar
Engine removal
Where is the best place to hook chain for 2004 CTD engine removel. It looks like if you try to use factory hooks the chain will hit the firewall before you get it out of the motor mounts.
Old Apr 7, 2007 | 10:51 PM
FMB's Avatar
FMB
If its like the '03, the rear engine lift bracket is bolted there just so you have it when you need it. The head bolts need to be pulled from #4 and #12 position in the head and the rear engine lift bracket is moved and bolted there. (on the driver's side, from the firewall, the bolts are numbered 24, 20, 16, 12, 8, 4, 1, 5, etc..., it is the torque sequence numbers.)
Old Apr 8, 2007 | 08:30 AM
97ramctd's Avatar
i dunno if an 03 would be any different but on my 97 i found that removing the motor mounts completely made it easy as pie to remove/install the engine.
HUNTINNUT
Jul 27, 2013 11:40 AM
The Mopar Dude
Sep 18, 2008 10:52 AM
trik396
Jun 1, 2008 07:04 PM
Checkmate
Feb 2, 2008 05:39 PM
JD730
Apr 22, 2007 08:04 PM
